Hi I have a F & P washing machine GW612. It has the seventh light come up in diagnostic mode. Is that error 2 & how do i fix it please? Thanks
Hi I want to help fix my mums washer. Its a Fisher and Paykel washing machine GW612. I think it's a phase 7. It has the seventh light come up in diagnostic mode. Is that error 2 & how do i fix it please? Thanks
Oeinnz,
According to the manual that I have, which is for different models so it might not be the same problem, it says something about a Pressure transducer frequency out of range(>90kHz). The primary source is the motor controller and the action listed is to replace the motor control module. I did find another updated manual and it has the same info, so it looks like you need to replace the motor control module.
Hi just read your posting.Starting from the left to right if the lights that are on when the machine is beeping are the 3rd and 4th and 8th then the error code is called COLD VALVE FAULTY.This means either your cold water valve is faulty or you control module is faulty.Would you like me to guide you in the testing and isolating the fault and replacing the faulty component?Please reply for further help.Looking forward to your reply.
Hi just read your posting,Now, does the machine show an ERROR CODE and beeps?If it does show an error code it will be in a number in your LCD DISPLAY if you have that model or a series of lights will light up.Now these lights will be in a row of 8 lights.Starting from the left to the right which ones are lit when the machine beeps?Is it the 2nd and 4th or the 1st and 5th ---etc---?Please reply with additional information and I am sure I can help you.
Hi just read your posting.The fault on your machine is called Single Rotor Position Sensor Error.The rotor sensor is attached to your motor which is located underneath the machine.Now the Error Code will come up on your machine because 1--The wiring to the Rotor Sensor is faulty. 2-- The rotor sensor itself is faulty or 3--- The motor controller, 'which is located under the top panel is faulty.Unfortunately to test the rotor sensor you need an RPS tester .This device will also check the wiring to the rotor sensor.If you have an electrical test meter I can guide you throe the testing of the wires to the rotor sensor but without the RPS tester you cant accurately test the rotor sensor.Some service techs I know just change the rotor sensor to see if that rectifies the fault but in your case you dont have a rotor sensor so even if you do purchase one and change it, the fault could be your Motor Controller.My best advice to you would be to borrow an electrical test meter if you do not have one and reply back and I can help you eliminate the Wiring as the cause of the fault,and then contact a service tech to find out if the fault is with the Rotor Sensor or the Motor Controller.But if the fault is with the wiring then I can guide you throe step by step to repair it.I hope this helps and please reply on how you got on or if you need further assistance.Good luck.
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies,
and visually check that the P11 connector is inserted all the way into
the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has
failed: Unplug washer or disconnect power. Replace the machine/motor
control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
and visually check that the P5 connector is inserted all the way into
the machine/motor control. If visual check passes, replace the user
interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or
disconnect power. Replace the machine/motor control assembly. Plug in
Some buttons do not light indicators:
and visually check that the console electronics and housing assembly is
properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
F then 2 flashes when in: Diagnostics Test mode if a stuck key is detected. Standby mode if there is a user interface mismatch. DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up: 1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control. 2. Visually check that the user interface assembly is properly inserted in the console assembly 3. If both visual checks pass, replace the user interface assembly. 4. Plug in washer or reconnect power. 5. Activate the Console and Indicators Diagnostic Test mode to verify repair. 6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard: 1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly. 2. Plug in washer or reconnect power. 3. Activate the Console and Indicators Diagnostic Test mode to verify repair. 4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators: 1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted into the front console. If visual check passes, replace the user interface assembly. 2. Plug in washer or reconnect power. 3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
control assembly.
interface assembly.
properly inserted
