The Dell user manual has the beep codes, which usually are in sequences with short pauses between. To figure out the problem one needs to know the spacing of the codes. Is it 1-2-3, or 2-2-2, or 3-1-2 or what? The first thing I would check is the RAM - make sure it is seated correctly, and try removing all but one stick.
To get monitor work for you, you should connect the VGA cable to CPU. When you remove the VGA cable, monitor has got nothing to display so it goes in stand by mode with orange LED on.
you should replace the motherboard or the power supply of your computer. to determine which one to replace is a simple test. disconnect all that is connected to the motherboard and if the problem is still there, then the problem is the motherboard.
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
I think you may be referring to the green power light and the orange hard drive activity light.you should have a power icon located on the bottom bar on the desktop near the clock that indicates battery power.
The power supply has most likely gone out. Check for 12v and 5v output and also the solder arround d903 and d907. The site www.lcdrepair.us sells the part as well as a repair kit and has instructions.
