Http://www.sharp-world.com/restricted/products/copier/downloads/select_us.html
try this
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
SOURCE: I need Vista 64-bit Edition drivers for a SHARP AR-M207
Select your model, and then "GPD_PCL6" from the drop "driver type" down menu here:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
SOURCE: I have an AR-M207 machine scanning error msg
Is it possible to ping top this machine? My i.t tech just whispered into my ear and said perhaps the machine can't scan perhaps because the authentication name/password (login name/paddword of your pc) has changed, so the copier doesnt have the permission to write information directly to your computer.
SOURCE: no drivers Win Vista 64 -Sharp AR-M207 !!
Go to
SOURCE: Does a Sharp ar m207 have the same scan board as
Got a service manual and looked up the parts ;)
