There is a vertical black bar exactly 1/15th (or about 97mm) the width of the whole screen that runs down the left side of the screen directly along the left side bezel. Is it a particular board or a faulty panel? Just to add some extra info while waiting for pic to be attached by fixit staff... Audio works perfectly fine. Vertical black bar is present on all inputs and digital TV. I have disconnected and reconnected every cable as well as leaving TV unplugged completely for at least 24 hours. Problem occurred 17 months after purchase and 6 months ago in February or March (the end of our Australian summer) but indoors does not get hot (maybe 30 degrees centigrade at most) and no direct sunlight. I pretty much live in constant air conditioning at 23 degrees year round. TV has always turned on without an issue when required. Problem occurred outside of warranty period. The whole remainder of picture is perfectly fine. The TV set has never been moved off the TV unit cabinet since initially been plugged in when bought brand new. Remote signal and all functions work. Side buttons on TV all work. All inputs work.
Can you provide a picture
Yes, still waiting for picture to be attached. I have emailed it through right after I posted this question. Thank you and please respond once pic is up.
It appears that Fixya staff do not want to attach the pic to this topic. I did email it to them via their instructions just after I posted this question but it is still not up yet a week later.
SOURCE: sharp lc26sh20u 26"flat panel has vertical lines on left side,What coulb be problem?
This line would either indicate a horizontal problem cropping up or a power supply problem
I would suggest getting a service tech to look at it to determine where
your problem is coming from but most likely it will be the power
supply /deflection board that is the problem but I can't know for sure, it will have to be checked.
A lot of sets have had damages after a long hot summer a/c
flipping off and on and current demand being peeked from the
utilities storms or quick power loss off and on can cause problems
like this to occur
Please let me know if you have any other questions, thanks
SOURCE: Sony WEGA KE-37XS910
This TV has a very expensive panel... we are talking $3000 core charge alone! It comes complete with all the lower buffer boards (which from the sound of it, you are having a problem with). Individual boards for this defect are not available on repair parts list I know of. A panel is what you need, PN: 9-885-063-33
SOURCE: MODEL: TH-50PZ85U I HAVE A VERTICAL
Hi
Thanks for using FixYa. As Plasma TV is a very hard working device so it produces lots of heat and around 75% issues in Plasmas are caused due to overheating. To start with you'll have to open the back of the unit and check for any bulged/bad capacitors on Y and Z-sus boards. As the sound is working fine so it seems that the power supply is fine, also check the control board for any bulged capacitors. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
