The error code SC93300 on a Ricoh 3110dn printer is not a known or recognized error code. It is possible that the code has been mistyped or is a custom error code specific to your printer model.
In general, Ricoh error codes starting with "SC" indicate a problem with the printer's hardware or firmware. To troubleshoot the issue, you can try the following steps:
Turn off the printer and unplug it from the power source.
Wait for a few minutes, then plug the printer back in and turn it on.
If the error persists, check for any visible damage or obstructions in the printer, such as jammed paper or a broken part.
Consult the printer manual or contact Ricoh support for more specific troubleshooting steps.
If none of these steps resolve the issue, it may be necessary to contact a Ricoh technician for further assistance.
This error is for a blocked magenta print head, so if you have done it allready, run the printer headcleaning routine, this is normaly found in the print driver under maintanance, or in the seperate software if supplyed
28113 - Ink supply timeout error (Tank 3 error)
• ink supply pump error
• air sensor error
• The tank feeler is malfunctioning.
• ink level senor error
• The ink supply pump is faulty.
• The carriage is faulty.
• The ink level sensor is faulty.
• The CTL board is faulty.
• Turn the main power switch off and then back on.
• Replace the ink supply unit.
• Replace the carriage unit.
• Replace the air purge detection switch.
• Replace the CTL board.
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
