Nabi 16GB DreamTab 8" Tablet Logo
It is frozen on the faces when it first starts up. does not even show the dreamworks words
2answers
How to Fix Kindle Paperwhite Frozen on Lock Screen?
Oops, are you troubleshooting the Kindle Paperwhite Screen Frozen problem? Have you tried all the possible ways to solve this difficulty? Not to worry, if the steps you perform don't work, we are here with some fully searched solutions that will help you to overcome Kindle Paperwhite Frozen on Lock Screen. Follow the guidelines step by step to get out of Kindle Paperwhite Screen Frozen matter easily on your own.
Steps To Solve Kindle Paperwhite Screen Frozen In Minutes
Charge The Kindle
A very common reason that leads to Kindle Paperwhite Screen frozen is the lower battery. It can be possible that you are facing screen stuck issues as of the empty or uncharged battery.
So, to let your device work properly you have to charge it first. Hopefully, charging your device will help you to overcome Screen frozen on Kindle.
Uninstall Corrupted File
If you have downloaded a wrong or corrupted file then you are definitely going through with Kindle paperwhite frozen on lock screen as well as scattering issues with Kindle.
Kindly uninstall the corrupted file as quickly as you can do, otherwise, it will cause damage to your device.
Can't move a picture on face book is it likely to be frozen?
You can't move a picture on Facebook.
Just hold your finger on and save it on your ipad.
My ipad is showing photo streaming with a message about the cloud and will not respond no matter what I do and I cannot even get it to power down
Press and hold both the home button (on the front) and the power button (top Right) until the iPad powers off and then on again.
How can I get my words with friends back?
Go to your app store, look under purchases and it will have everything you ever bought or downloaded there waiting for you :)
My tab is frozen
If your tablet is frozen what until the battery gives out.
Once it gives out charge it and turn it on if that doesn't work try this.
Get something small like a pin somewhere on your tablet there should be a little circle and the words RESET stick the little object in there hold it for five seconds and let it go your tablet will restart and reset. If that doesn't work your tablet is defected you need to take it back to the store you got it from
2answers
Once i charge the kurio the screen comes on with the smiley face and thats it
Sounds like the "frozen screen" issue. Hold the on/off button of the tablet well also pressing the Volume+. This should FIX it and unfreeze the screen.
LindaSView
Frozen screen
hold the re-set button down until the tablet shuts itself down if you have already done this and it does not work and you have had your tablet for less than a year usually the company will fix it for free or send you a new one free of charge because it is a problem with tablet not something you did.
Top Nabi Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
techy
Level 1 Expert
Ari Garcia
Ari Garcia
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
