Working fine then suddenly stopped, the on/off button makes the horn noise when trying to turn it on and nothing happens. Red light under the battery flashes 3 times
Horn(s) are typically located under the hood, behind and near the headlight assembly. It is not uncommon for a horn to stop working over time. It is also not unlikely that horn button in the steering column fails. To verify that the button is working, get the car to a very quiet location. Turn off all radios, blowers, etc. to make the car interior as quiet as possible. When you press the horn button, listen for a "click" noise from under the dashboard. This is the horn relay. If that happens, you know that the button(s) in the steering wheel are ok. If you don't hear the click, then the horn button or the horn relay may be the cause of the horn not working.
The clicking noise from fuse box is probably a relay! Nothing happening could mean anything! Without turning the ignition can you turn on headlights, does the inside light come on when you open the door, horn work?
check connection from battery live to relay, from relay to starter. cross the 2 bolts on relay (will spark) does this turn the engine, if so the starter button to relay is faulty or the relay is faulty
press the button on the wireless station then press the button on the mouse it should see it if it doesn't then you may need a new mouse. you can also test the batteries to make sure they have 1.5 v
Tilt the steering wheel down all the way and see if it starts, if it does then there is a main power wire loose in the steering columb. Thats all which comes to my mind at this time.
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
even if your starter is out it would still click when you tried starting the car. so try replacing your battery first thats the most common problem for random starting. also look under the car you may need to jack it up. look under the intake manifold that is where the starter is check to see that everything is hooked correctly and that all the bolts are tightend securley and not loose on one side.
remove the SD Card and the batteries. Wait for half an hour and then insert two new batteries. Do not put the SD card in as yet. (Waiting for half an hour or more allows the camera to reset itself).
