Question about Ricoh Aficio 1515MF All-In-One Laser Printer
What is a photo conductor - Ricoh Aficio 1515MF All-In-One Laser Printer
  • Ricoh Master
  • 1,915 Answers
The photo conductor is the round drum unit that is light sensitive. The laser in the printer writes an image of what you want to print on the drum and then the toner is applied to the drum and transferred to the paper.
Posted on Aug 30, 2015
6ya staff
SOURCE:
Need a replacement photo conductor for Savin 816
Fixya does not sell replacement photo conductors.
Dec 07, 2017 | Savin Office Equipment & Supplies
IS THERE A TRICK TO INSTALLING THE PCU ON THE CL3500N? IT SEEMS AS THOUGH IT SHOULD BE A SIMPLE PROCESS HOWEVER IT IS NOT LOCKING INTO PLACE. THANK YOU
Photo Conductor Unit Color
A Turn off the power, and then unplug the power cable.
B Open the right cover.
C Pull out the green levers on the left and right that are securing the inner
cover.Replacing
D Lift the inner cover until it stays up.
E Remove the photo conductor unit.
F Pinch the
green lever to unlock the unit.
G Pull out the photo conductor unit carefully.
H Pinch the green lever to unlock the unit.
I Pull out the photo conductor unit carefully until it stops.
J Pinch the green part to release the unit
.K Pull out the photo conductor unit carefully. Be sure to hold the unit with both hands, and pull it out carefully.
L Take out the new photo conductor unit.
M Remove the cap attached to the photo conductor unit. The cap is no longer needed and can be disposed of.
N Remove the tape from around Photo Conductor Unit by peeling it down-ward, and then remove the unit
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2011 | Ricoh Aficio CL3500N Laser Printer
Everytime we print there are dots down the left hand side of the paper
You may have a build up of toner on your photo conductor unit. With a soft dry cloth carefully wipe the Green tub after which is located behind your toner cartridge it is the photo conductor unit.
Apr 16, 2010 | Lexmark E120 Laser Printer
Reset pcu correctly
Hi
Thanks for using FixYa. It means that the photoconductor unit is not set correctly. You’ll need to reset the black or color PCU correctly. Match the green arrow at the tip of the photo conductor unit to the rail inside the printer. Make sure the green arrow fits securely on the rail before proceeding to the next step. If you do not attach the green arrow of the photo conductor unit securely to the rail, you may damage the photo conductor unit. Push the front of the photo conductor unit slowly, sliding the unit on the cover and into the machine until it stops.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 31, 2010 | Gestetner Office Equipment & Supplies
Install Photo Conductor
Perhaps, it is necessary to establish the necessary software.
http://filters.atspace.com
Aug 10, 2009 | Epson Aculaser C1100 Printer
Reset Photo Conductor Kit
Hi!
For step by step procedure to reset Photo Conductor counter please see the following link---
Photo Conductor Counter Reset
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 02, 2009 | Lexmark E450dn Laser Printer
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
Pc drum
Replacement of the Photo Conductor Unit
1. Select Tech. Rep. Mode → [Counter] → [Special Parts Counter] → [PC Life].
2. Press the Clear key to clear the counter value.
3. Turn OFF the main power switch.
NOTE
• Clear the PC Life counter before removing the IU.
• After clearing the PC Life counter, be sure to turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU. Carefully pull on the two green handles
6. Remove four screws (silver) on the sides and disassemble the Photo Conductor from the Developing Unit.
7. Replace the Photo Conductor Unit
8. To reinstall, reverse the order of
removal.
NOTE
• Replace the Toner Filter (Developing
Unit) with a new one at the same
time.
Jun 06, 2008 | Office Equipment & Supplies
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
