2001 Mercedes-Benz S-Class - S320 L, long wheelbase - Form Fit Car Cover Logo
a
ayodele tawakalitu Posted on Aug 30, 2015
Pls what is the causes of inner mirror and side mirror with power seat botton that has not power
Where is the power control circuit located and I need the coloured code of cable that supply the circuit.
Sandrah DeGonge Daggett
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 17, 2015
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
401
Points
7
2008 Ford Edge heated Seat will not turn off. It does not matter which position the on off button is in, the seat and back heat stays on
Heated Seats
This system allows independent seat electrical heating of each front seat on demand.
The components of the system are:
  • the seat heater mats located on the seat cushion and backrest.
  • the heated seat module located on the passenger power seat track and cushion frame on manual seat track.
  • the heated seat switches, located on the electronic automatic temperature control (EATC) module.
  • temperature sensors, located in the seat cushion heater mats.
A new heater mat will come assembled on a new foam pad.
Climate Controlled Seats
The climate control seat system is able to heat and cool the front seats. Each climate controlled seat is operated by push-buttons on the electronic automatic temperature control (EATC) module located on the instrument panel. Each front seat temperature is then monitored and controlled by the climate control seat module (CCSM) located on the front passenger seat track.
The climate controlled seat system contains the following components:
  • EATC module
  • CCSM
  • Thermo-electric device (TED) and blower assembly within each front seat cushion and backrest
  • Air filter (attached to each TED and blower assembly)
  • Cushion TED adapter attached to the cushion frame
  • Cushion and backrest manifolds
  • Cushion and backrest foam pads
  • Cushion and backrest trim covers
  • Seats
    Front Seats
    NOTE: The high speed controller area network (HS-CAN) circuits that pass through the passenger seat harness are part of the main HS-CAN LOOP. If the front passenger seat-to-floor connectors are disconnected, a NO START condition will result.
    NOTE: The medium speed controller area network (MS-CAN) circuits that pass through the driver seat harness are part of the main MS-CAN LOOP. If the front driver seat-to-floor connectors are disconnected, various MS-CAN modules will not be able to communicate.
    The front seats can be equipped with the following systems:
    • Two-way manual seat track (passenger only)
    • Four-way manual seat track (driver only)
    • Six-way power seat track
    • Manual recline
    • Power recline
    • Backrest, without fold flat
    • Backrest with fold flat (optional, passenger only)
    • Heated seats
    • Heated/cooled climate controlled seats
    • Memory driver seat
    • Manual lumbar (driver only)
    • Power lumbar
    • Adjustable head restraints
    • Seat side air bags (standard)
    • Occupant classification sensor (OCS) system on passenger seat
    Driver Seat Module - Memory Seat
    The power driver seat, power outside rear view mirrors and power adjustable pedals are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option. The DSM is located on the driver seat track.
    This system allows automatic positioning of the driver seat to 2 programmable positions.
    • A power driver seat position can be stored at any time. The driver must move the seat to the desired position using the driver seat switch assembly. The driver must then depress the memory SET switch which activates the memory SET switch light emitting diode (LED). Within 5 seconds (before the LED goes out), the driver must select a memory position. Memory 1 is selected by depressing memory switch 1. Memory 2 is selected by depressing memory switch 2.
    • If no memory switch input is received within the 5-second time limit, the operation is aborted and the memory seat position switch (set switch) LED is turned OFF. This also occurs if one of the following inputs is received during the 5-second programming limit:
      • Driver seat control switch
      • Memory seat position switch (set switch)
      • Power adjustable pedal switch
    A programmed seat position can only be recalled when the transmission selector is in PARK or NEUTRAL with the ignition switch in the RUN position. A position may be programmed at any time.
  • Principles of Operation
    Driver and Passenger Power Seats Without Memory
    The driver and front passenger power seat motors are hardwired to the seat control switches on each respective seat. The circuits are normally at ground through the seat control switch. Each individual seat track, recliner (if equipped) and lumbar (if equipped) motor circuit is switched to power when the specific adjustment position is selected.
    Power Driver Seat With Memory
    The driver power seat is controlled by the driver seat module (DSM), if equipped. The memory driver seat feature allows the driver to program a personalized seat position that can be recalled using the memory switch or a remote keyless entry (RKE) transmitter. There are 2 memory settings possible. The outside rear view mirror positions are also stored and recalled with the power driver seat positions.
    The DSM is located underneath the driver seat cushion frame. The DSM does not require calibration to the driver seat track.
    The driver seat control switch provides voltage to the DSM when activated. The NEUTRAL position of each driver seat control switch position is a ground state through the seat control switch contacts. A voltage input causes the DSM to power the appropriate motor until the input is removed. Ground is the normal state of the motor circuits through the DSM and is not switched to control the motors. The DSM internally switches the appropriate circuit from ground to power for operating the motors.
    As the seat is adjusted, the DSM constantly monitors the motor position sensors to record the current seat position. The DSM will remove power from the motor upon termination of the seat control switch input or if the DSM does not see movement from the motor by monitoring the position sensor.
    The DSM communicates diagnostic trouble code (DTC) and other information using the MS-CAN communication bus. It should be noted for diagnostics that because CAN bus communication is more robust and reliable than other methods, it may be possible to have limited module communication with one of the CAN bus circuits disconnected or shorted to ground. Refer to Section 418-00 for information concerning MS-CAN bus communication.
Do you have memory or not ?
Taking the vehicle to a qualified repair shop an having a diagnostic scan of the seat module's done could save time an money , by not replacing parts needlessly .
1helpful
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Which fuse controls front windshield wiper pump
Do the wipers work ? Fuse for wipers is same as washer pump .
The wiper motors receive inputs from the following:
  • Multi-function switch
  • Powertrain control module (PCM)
  • Ignition switch
  • Smart junction box (SJB)
The following components are integrated in the wiper motors:
  • Windshield wiper motor module
  • High/low speed relay
  • Run/park relay
  • Washer pump relay
  • Park sense (Hall-effect sensor)
Washer System
The windshield washer and the rear window washer are activated by the internal wiper motor modules when it receives a ground from the multi-function switch between the washer inputs. Depending on the correct ground, the internal wiper motor modules activate either the windshield washer or rear window washer relays (internal) by grounding the respective relay coil. When either module is activated, it connects voltage to the washer pump while the deactivated module provides ground to the washer pump. In this manner, voltage polarity is reversible to achieve directional change of the washer pump and washer fluid.
  • The washer pump is inoperative
  • Circuitry
  • Washer pump
  • Rear window wiper motor
  • Go To Pinpoint Test I .
Does your expedition have programmable/recall memory option for seats an mirrors ?
Driver Seat Module
The power driver seat and power exterior mirrors are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option.
On the Expedition Limited, the power fold exterior mirror option is controlled by the DSM. Before running a self-test or retrieving codes, the power fold switch must be inactive for at least 30 seconds.
This is a complex vehicle , electronics , control modules an serial data communication networks. You mite be better off taking it to the dealer or some other repair shop . There could be DTC'S - diagnostic trouble codes stored in the SJB - body control module !
B1667 Mirror Driver Up/Down Motor Stalled Go To Pinpoint Test D . B1668 Mirror Driver Right/Left Motor Stalled Go To Pinpoint Test D . B1669 Mirror Passenger Up/Down Motor Stalled Go To Pinpoint Test D . B1670 Mirror Passenger Right/Left Motor Stalled Go To Pinpoint Test D . B1735 Mirror Driver Vertical Switch Circuit Short to Battery Go To Pinpoint Test D . B1739 Mirror Driver Horizontal Switch Circuit Short to Battery Go To Pinpoint Test D . B1743 Mirror Passenger Vertical Switch Circuit Short to Battery Go To Pinpoint Test D . B1747 Mirror Passenger Horizontal Switch Circuit Short to Battery Go To Pinpoint Test D . B2312 Mirror Horizontal Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . Normal Operation During normal operation, when the front wiper wash is selected, the windshield wiper motor provides power to the washer pump through circuit CRW14 (BU/WH) and ground is provided to the washer pump through circuit CRW12 (GY/OG) and the rear wiper motor. If rear wiper wash is selected, the rear wiper motor provides power to the washer pump through circuit CRW12 (GY/OG) and ground is provided to the washer pump through circuit CRW14 (BU/WH) and the windshield wiper motor.
    Possible Causes
  • Open in circuit CRW14 (BU/WH), CRW12 (GY/OG), CRW07 (GY/BN), CRW20 (GY/YE), SBB49 (RD) or GD149 (BK/GY)
  • Short to ground in circuit CRW14 (BU/WH), CRW12 (GY/OG), CRW07 (GY/BN) or CRW20 (GY/YE)
  • Washer pump
  • Rear wiper motor
    This is
How do I remove the driver side door panel on a 1994 Lincoln Mark VIII
Remove mirror mount cover assembly.
Remove inside door handle cup (22634).
Remove door lock control bezel.
Remove window control bezel.
Remove interior lamp lens.
Remove screw from interior lamp assembly body.
Remove screw from window control bezel opening.
Disconnect mirror, lock switches and memory seat on driver side from bezels and wire harness.
Disconnect window switches from window bezel and wire harness.
Lift front door trim panel (23942) vertically, out of weatherstrip and over lock rod.
Disconnect interior lamp (13776) from wire harness.
Remove front and rear door trim retention hooks into door inner panel.
To install, reverse Removal procedure, paying special attention when inserting inner door trim into weatherstrip. Rock inner door trim into weatherstrip and push downward until lower trim belt character ditch lines up with score mark on inner door panel.
Memory seats adjust on there own as well as mirrors
BCM has nothing to do with this function , MMM - memory mirror module !
Memory Mirror System Operation
The MMM is capable of storing mirror position for 2 different drivers. Mirror position is determined by both horizontal and vertical position sensors in each of the power mirrors. The MMM supplies a reference voltage and a low reference to these sensors and determines mirror position through the horizontal and vertical position signal circuits.
The MMM receives power through the battery supply voltage circuit and the MIR/LOCK fuse and a constant ground source. Any time that battery voltage is disconnected and then connected from the MMM, the MMM will enter the mirror relearn mode. The mirror relearn mode can also be commanded using a scan tool. Refer to Memory Mirror Module Learn for further information.The memory switch receives power through the battery supply voltage circuit and the MIR/LOCK fuse. The MMM upon receipt of a memory switch signal input, a class 2 message from the SIC or a class 2 message from the PCM indicating that the transmission is in park, will then supply battery voltage and ground to the appropriate power mirror motors through the mirror motor control circuits to move the mirrors to the predetermined positions.
DTC B1586, B1596, B1616, or B1626
The mirror horizontal and vertical position sensors are potentiometers. The Memory Mirror Module (MMM) provides these sensors with a 5 volt reference circuit and a low reference circuit. The MMM monitors the horizontal and vertical position sensor signal circuits which change values based on mirror position. These voltage values are used to determine mirror position and can be set into memory. When the MMM receives a memory recall request, the MMM will control the power mirror to the memory position based on the horizontal and vertical position sensor signal values.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Memory Mirror Module (MMM) data list.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Memory seat module
• Memory mirror module
• SEAT 25A circuit breaker
• MIR/LOCK 3A fuse
Your best bet , take it to a qualified repair shop !
2008 Buick Enclave; front passenger, no power to window and lock controls, and no power to passenger side mirror. Additionally, passenger heated seats do not operate. From driver seat control, I cannot...
Do you know anything about automotive electronic's ? Serial data Communication network ? Electronic module's inside the vehicle doors , communicate commands ! No relay ,no fuse .
If the passenger mirror is selected and a direction switch is activated, the DDM sends a serial data message to the PDS indicating that the passenger mirror was selected and the direction to be commanded. The PDS will then supply battery voltage and ground to the appropriate control circuits for the direction selected.
DDM - driver's door module
Door Lock System Components
The power door lock system consists of the following components:
• Driver door module (DDM)
• Passenger door module (PDM)
• Door lock relay--Located in the instrument panel (I/P) fuse block and controls the locking of the rear doors.
• Door unlock relay--Located in the I/P fuse block and controls the unlocking of the rear doors
• Body control module (BCM)
• IP BEC
• Reversible door lock actuators in each door
Power Window System Components
The power window system consists of the following components:
• Rear door power window switches
• Power window motors in each of the doors (circuit breaker protected)
Your best bet , take it to a qualified repair shop that has a diagnostic scanner that can pull code's an view input data form these systems . There is one circuit breaker for the window's an fuse's for the lock's . I would think a data network problem . But that would be a guess , without testing anything is possible on these .
2002 RX 300 Power mirrors do not work (both sides) with dashboard control. Looked for fuse "power mirror" but none shown. Is this mirror control tapped off of another circuit? Would you know...
That accessory will probably probably be grouped with other accessories on one fuse. So it will not be the label. Check visually for the blown fuse. There will probably be other accessories that don't work as well, such as the seats or some minor power driven device. Visually you can see if a fuse is blown
A good flashlight helps when looking, if the fuse box is in a tight location.
Best,
Mark
2008 Chev Suburban 4wd Z71 1/2 ton; several items on my passenger side stopped working: my passenger side front seat heater stopped working; the passenger side electric mirror stopped working; the signal...
Power windows an locks work ok ? Do you know anything about automotive electeronic control modules ?
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• Driver Door Switch (DDS)--An electronic control module with integrated switches and requires programming when replaced
• Passenger Door Switch (PDS)--An electronic control module with integrated switches, requires programming when replaced
• Power Mirror Direction Switch--Integrated into DDS and is a 4 position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a 3 position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Left Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Right Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Body Control Module--An electronic control module that requires programming when replaced, serves as the power mode master and is the main message handler
• Memory Switch, if equipped with memory mirrors--Supplied power by the DDS and provides a voltage signal to the DDS upon a switch activation
• Horizontal and Vertical Position Sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDS/PDS and provide a variable voltage signal to the DDS/PDS that is proportional to mirror position
• Powertrain Control Module (PCM), if equipped with memory mirrors--An electronic control module that requires programming when replaced and provides the message indicating transmission gear selection
• Driver Information Center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a an electronic control module that requires programming when replaced and is used to personalize the memory recall functions
• Fold Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B1023
Circuit/System Description
The driver door switch (DDS) and front passenger door switch (PDS) each contain switches that control power door lock and window functions. The DDS also contains the control switch for the power outside rear view mirrors. These switches are integrated within the door control modules and are not serviceable as separate components. The DDS and PDS monitor these switch inputs for internal faults and set B1023 00 if any are detected.
You could have any number of problems an without testing , hooking up a scanner that can check DTC'S in the door module ,electrical circuit testing etc... we'd only be guessing . Your best bet mite be to take it to a qualified repair shop.
2helpful
3answers
1995 jaguar driver seat won't move.
You might want to try disconnecting the negative battery cable for 5 minutes and then reconnecting it. This procedure fixed my seat that was not working. It works fine now. I know it sounds too good to be true but it usually works
My side mirros dont work
The exterior mirrors:
  • are controlled by power controls on the LH front door trim panel.
  • are of a foldaway design.
  • may contain turn signal indicators.
  • may be heated when the heated back window glass is activated.
  • may have a programmable recall memory option.
Driver Seat Module
Power Exterior Mirror Operation
The power exterior mirrors are controlled by the DSM and are operational all the time, whether the ignition switch is on or off. Using the power exterior mirror switch, the driver can adjust the driver and passenger exterior mirrors four ways.
Visual Inspection Chart Mechanical Electrical
  • Exterior mirror(s)
  • Interior mirror
  • Central junction box (CJB) fuse
  • Circuitry
  • Exterior mirror control switch
  • Exterior mirror motor
  • Interior mirror
  • Driver seat module (DSM)
  • Memory set switch
  1. If the vehicle is equipped with memory exterior mirrors and the concern remains after the inspection, connect the diagnostic tool to the data link connector (DLC) located beneath the instrument panel. Select the vehicle to be tested from the diagnostic tool menu.
    • Check to make sure the program card is correctly installed.
    • Check the connections to the vehicle.
    • Check the ignition switch position.
  • The mirrors are inoperative
  • Circuitry.
  • Central junction box (CJB) fuse.
  • Exterior mirror control switch.
Top Covercraft Vehicle Parts & Accessories Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
