Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/ Generator Guru
I presume you mean the radio/cd cuts out and not the engine. I also presume you are not letting the bike idle away as you listen to music! If you are, then the bike is over heating and piston seizure is the causing it to stop. Now, if it is just the radio/cd unit cutting out, the radio/cd unit has developed a thermal fault that requires specialist attention. Nothing you can do.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Possibly an internal short in the torch tip... the expendable components failing in the tip will cause the sensors in the machine to register a "no cut" or "free air arc" state and kill the power to the tip to prevent damage to the unit. Replace the tip components and double check the grounds connections.
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
I have had this problem with a Fujitsu unit before. If the power is supplied to the outdoor unit first but unit is meant to have power supplied to indoor unit first, outdoor will only stop when power is cut off! In that case, you will have to run the power cable to the indoor unit first and then connect from appropriate terminal back to outdoor unit. (Often the indoor will stop outdoor unit by just cutting the power to it via use of a relay on the pcb.)
check the fan timer if equipped. check stat wireing and make sure it is on auto. remove wire on g from stat and motor should stop.check for power to motor and remove on control or wire at a time unit it stops running
-If both compressor and fan motor starts and stop, thermostat is the defect. - If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
