Lands Phones Logo
L
Linda Hamilton Posted on Sep 02, 2015
All I want to know is how to shut off my vetch phone answering machine so I can add one with speaker voice. The model I have is CS6719-2
Florencio Gonzales
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Sep 06, 2015
Florencio Gonzales
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
4156
Points
28
Answering system settings
Answer on/off:
The answering system must be turned on to answer and record messages.
When the answering system is turned on, the /ANS ON/OFF light on the telephone base turns on and ANS ON displays on the handset.
To turn on or off with the telephone base:
• Press /ANS ON/OFF to turn the built-in answering system on or off when the phone is not in use.
When the answering system is turned on, it announces, "Calls will be answered." When the answering system is turned off, it announces, "Calls will not be answered."
To turn on or off with a handset:
1. Press MENU when the phone is not in use.
2. Press DOWN arrow or UP arrow to scroll to Answering sys, then press SELECT.
3. Press DOWN arrow or UP arrow to scroll to Answer on/off, then press SELECT.
4. Press DOWN arrow or UP arrow to choose Answer: On or Answer: Off,then press SELECT to confirm your selection. You hear a confirmation tone.
Hope this will help.
5 Related Answers
A
Anonymous
  • Posted on Sep 26, 2007
SOURCE: cordless phone answering machine
To go back to English you press and hold the Skip button. If you need other assistance with it, the support number for GE Phones is.... Thomson Inc. @ 1-800-448-0329
Anonymous
  • Posted on Dec 14, 2007
SOURCE: Answering machine/voice mail
There is no voicemail for this model.
Anonymous
  • 65 Answers
  • Posted on Feb 25, 2008
SOURCE: setting up my phone
I WAS UNABLE TO FIND A MANUAL FOR THIS MODEL BUT GO HERE AND DOWN LOAD THE INSTRUTIONS FOR THIS ONE THEY PROBABLY WORK SIMULARLY.http://www.home-electronics.net/ge/pc/viewPrd.asp?idcategory=33&idproduct=37
AvioriX
ExpressFiX
  • 691 Answers
  • Posted on Nov 16, 2008
SOURCE: Need a User guide
Hi
You can get it from the link below,
http://www.expressfix.net/manuals/Phones/GE25881EE3-A
k24674
  • 8093 Answers
  • Posted on Sep 14, 2009
SOURCE: I lost manual to 6.0. I have answering machine set
Here is the link to Dect 6.0 manuals. Select model and download.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Hope it helps.
1helpful
I accidentally deleted my important messages from my vetch answering machine, is there any possible way to retrieve them? The voices of my parents who both passed last year were included.
Not likely, unfortunately. You might try using Google to see if you find any suggestions that help. One advice I saw was to disconnect the telephone line because new messages would record over the old messages on some types of answering machines..
It would help to know the manufacturer and model to help determine what is inside it that might be taken out and checked by a technician. Do you have someone to help open it up if needed to check inside?
Is it a Vtech and not a vetch?
KX-TG5621C changing number of rings
The KX-TG5621 isn't an answering machine. It will ring until you answer, some answering machine picks up, or the caller hangs up.
To change the ring count on your answering machine, refer to the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
I can make calls but why can"t i receive calls on my vtech cs6649-2 phone?
Check out your manual for troubleshooting. Google the phone and model # with your question. I have a guess the ringer is turned OFF or wiring is not correct. Good luck.
How do I check my voicemail on my vetch dect 6.0 cordless phone?
Enter the model of your VTech DECT 6.0 phone/answering machine into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
If the messages are on a voicemail system provided by your telephone company rather than on an answering machine attached to your phone, then please contact them for instructions on accessing their voicemail system.
Vetch cordless phone says not registered and will not work....need help?
The handset needs to be registered with the base unit. Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual and see how to register the handset to the base.
Manual for vetch 5.8GHz
Since you didn't specify the model of your VTech 5.8GHz system I can only suggest you enter it into the search box here to download a copy of the manual.
How do you put people on speaker phone on my vetch wireless home phone?
Since you declined to specify the model of your VTech phone, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
