1. Make sure the mic is not set to mute.
2. Check your battery charge. Low charge may turn off video.
3. Your operating system appears to be Marshmallow. I am not sure what application you are attempting to use for voice chat. It might be Google Duo, Facebook Messenger, Hangouts, or Imo, among others. If an application is not working, one generally tries reinstalling it.
4. Another application may be running and blocking use of the mic. Check what else is running. I think holding down the home button will reveal what is running. Shut down background apps and test the app you are using. Google Play may have What's App to check this.
Try recording using the voice memo to check the mic if you can then mic is working if not then either downgrade your ipsw to the previous firmware if you are sure it stopped working right after the software upgrade or replace the mic
regularly it should be on working , try to call with simcard , if it works fine mic is ok and app has problem , you should uninstall then install other version
The microphone for the nexus 7 is a small hole on the right hand side of the tablet, just below the volume button. Make sure your hand and any cases you're using aren't covering this when you're trying to do a voice search.
First, try pluging in an exteral mic to check the mic itself is not broke. Next Go to the device manager to check for driver problems (control panel, system, Hardware look for yellow ?'s) Check control panel, Sounds and Audio, audio, sound recording, volume. There are just too many ways to mess with the sound settings, and they often seem to just mute themselves! Good luck
I read the question and i suggest that if the notebook has inbuilt microphone then the mic is already enabled if u have installed the proper drivers but if u plug in external mic then check the pin and socket of microphone. if this does not work go to control panel and then sound and then check the microphone
