SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
SOURCE: error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
SOURCE: My ir canon photocopier shows
if you are changing the machine room from cold to warm, it can causes the error code E100, it's a condensation of the laser sensor. to solve this problem you need change the laser sensor PCB or the laser unit. or try to warm up the pcb sensor with a hot air. look at the picture to identify the laser sensor:
