SOURCE: canon 6260 photocopier error E214
i have conon irc2100 i wanet this michine conect with computer plese your solution
SOURCE: error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
Change the toner not use originol toner same time coming err cod e000020 must be use orignol toner
