Memory error 928. The machine detects a discrepancy in the write/read data during its write/read test (done at power off/on and at recovery from low power or night/off mode). • Memory defective • BICU defective • Poor connection between BICU and memory
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
The SC - 928 is a Memory error problem. The machine detects a discrepancy in the write/read data during its write/read test (done at power off/on and at recovery from low power or night/off mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes: • Memory defective • BICU defective • Poor connection between BICU and memory The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
