The motor will work at any speed for a few moments and then slow down to a stop. I will turn it off and on again with no result. After a few days it will work again and stop. It is almost 5 years old and used several times a week.
Mine did almost the exact same thing one day. I have the Artisian Model, It would do it on any of the lowest speeds. Dont know if this will help you or not but I just ran mine the next day on all the way high with the spash guard on for making whipped cream for about 6 minutes full throttle and for some reason it hasnt went slow and shut itself off since then. Mine is about 7 months old. I called Kitchen Aid but their customer service all of a sudden seems to not know english worth a poo...
Try running yours on full blast for 5 minutes with something simple in the bowl. If its a 250 watt or higher make whipped water out of 2 cups of water and a tablespoon of cornstarch. Run it till you get what looks like whipped cream. Oh yea. Use the Balloon whip. The lubrication in the motor is supposed to last for at least 5 years but I have seen on numerous post's that if you run them on all the way for at least 5 minutes the oil will even out in the motor. Running the mixers at low speed alot will cause the oil inside not to move as freely since the motor doesnt heat up the oil in the gears.
Good luck.
