Question about RCA Universal Remote Control
My TV set power button does not work. Can I program it using my remote control without having to turn it on first?
6ya staff
SOURCE:
Anonymous
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
Posted on Oct 08, 2008
Anonymous
SOURCE: programming my remote
http://66.77.167.109/rcaaccessories/BrandCode.do
go here for your codes to any rca remote
Posted on Mar 22, 2009
Anonymous
SOURCE: I have a rca remote
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Posted on Jun 21, 2009
Anonymous
SOURCE: Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
Posted on Aug 22, 2009
Trying to program cineplus remote for panasonic dvd player
Try this as all remotes work about the for manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 28, 2009 | Televison & Video
I need the code for the philmore pm-rc1a so i cant watch my tv!
Try this as most remote controls work the same when manual setting.
Note:
Have a Jumbo big remote. Lost all codes for the TV and video, need them to program jumbo big remote.
Try this as all remotes work about the same when manual setting.
Note:
I want to set up my remote clu 5729tsi to the cable box
Note:
Sep 28, 2009 | Hitachi CLU-5713TSI Remote Control
I NEED CODES FOR MY SANYO TV
Note:
Sep 28, 2009 | GE JASRM24912 Remote Control
Need code to re-set GE rc24912-e remote for a Sanyo tv.
Note:
Sep 25, 2009 | GE JASRM24912 Remote Control
Need the codes to tune in my brookstone remote control to my childrens phillips tv
Try this, it should work. Just be patient while going through this set up.
Note:
Sep 21, 2009 | Brookstone 538744 Remote Control
Programming problem
a universal remote control is programmable without codes using this general process:
  • push and hold 3 sec the button set up
  • select the device to control (TV DVD etc)
The tv has to be ON at this step (use the power button in the tv front panel
  • use the remote control power button and try to get your tv pushing the button again and again and again
  • Caution! Go slow because when finally the tv turns on you have to push enter in the remote control to save this code that actually is the one the tv needs,
Apr 14, 2009 | Radio Shack 15-2142 Remote Control
I have a phillips universal CL034 remote control and i dont know the code or how to program it to my television
without knowing the brand of the tv i have to give you generic instructions on how to program the remote without knowing the codes:
  1. Turn your tv on manually
  2. on the remote press TV once
  3. Press and hold the set button until the LED red light blinks twice, then release the set button
  4. enter 9-9-1. the led will blink twice
  5. aim the remote at the tv and slowly alternate between pressing POWER and TV. Stop when the TV turns off after pressing power.
  6. lock in the code by pressing and releasing the set button. the led will blink twice.
Jul 02, 2008 | Televison & Video
Televison & Video Logo
135 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
