Question about Samsung Galaxy Tab 2 7.0
How can I connecr again after note keeps showing disabled?
    Top Expert:
  • Samsung Master
  • 65,416 Answers
Perhaps contacting your service provider from another phone will get you answers to this .
Posted on Sep 12, 2015
6ya staff
SOURCE:
How do I get my Samsung tab 4 off samsung retail mode
Go to the app called Retail Mode. First password is 5444, then you will click off disable retail mode. It will ask you again for password. Then you will use the M729Q16K8546 password. It will then ask you if you want to factory reset device. Click yes. NOTE: This will wipe your data.
Jul 13, 2018 | Samsung Tablets & eReaders
How do I delete all my google apps
You can remove apps from your device if you don't want them anymore or you need to clear memory space. If you uninstall an app you paid for, you can reinstall it later without buying it again.
Uninstall or disable apps
  1. Open your device's Settings app .
  2. Tap Apps or Application manager.
  3. Tap the app you want to uninstall. You may need to scroll to find the app.
  4. Tap Uninstall or Disable.
Uninstall vs. disable There are two ways to remove apps depending on whether you downloaded the app or if it came preinstalled on your device:
  1. Uninstall downloaded apps: If you downloaded an app from Google Play, you can completely remove it from your device.
  2. Disable preinstalled apps: Some apps come preinstalled on your device. You can disable these apps, but you can't remove them completely. After an app has been disabled, it will be hidden on your device.
Note: Disabling a system app may cause other apps to misbehave and will delete your associated data for that app.
You can find more information here:
https://support.google.com/googleplay/answer/2521768?hl=en-GB
Dec 05, 2016 | Tablets & eReaders
My phone keeps on displaying this massege:- "unfortunately, the process com.google.process.gapps has stopped." how can I solve it
Hi the gapps in the error refers to Google apps ENABLE THE DOWNLOAD MANAGER..step 1 : tap on apps ..step 2: tap ,& drag the application screen towards the right to access settings ,& then tap on settings icon 3: tap on more 4: tap on application manager under more tab. 5: now tap & drag the application manager screen towards left and access DISABLED application ( note if disabled tab is not available.go TO ALL TAB,) 6,: tap on download manager with Android icon. 7: tap on enable now Download manager is enabled ( disabled should B on screen ) ...8 restart you're device ...good luck
Jun 19, 2016 | Tablets & eReaders
Tablet can not connect to wi-fi
Try "forget network" and reconnecting.
Dec 06, 2013 | Samsung Galaxy Note 10.1"
My wireless connection is disabled how do I correct
  1. Swipe down from the top of the screen to show Quick Settings, and then tap Wireless.
  2. Verify that Airplane Mode is Off.
  3. Next to Wi-Fi, tap On.
  4. Tap a network to connect to it. If you see a lock icon, a network password is required. Enter the Wi-Fi network password, and then tap Connect.Note: If you don't know the password, check with the person who set up the network. This password is not your Amazon account password.
After you connect to a Wi-Fi network, your Kindle Fire automatically connects to the network again when it's in range. If more than one network is in range, your Kindle Fire automatically connects to the last network used.
[Source]
Nov 01, 2013 | Amazon Kindle Fire HD
My kindle fire HD 7 the wireless is disabled. How do I undiable it. thanx
[Source]
Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Feb 27, 2013 | Craig CMP741d Tablet
After few minutes the pointer jumps to the left or right corner
Since you are working on a Tablet PC I'd start by disabling the Table PC Input Service..most people never use it and it will make your system much more stable overall, and may solve the cursor problem. see this article for help on how to disable it..
http://msdn.microsoft.com/en-us/library/ms812266.aspx
Jun 22, 2009 | IBM ThinkPad X41 Tablet PC
Fujitsu Seimens T4010D Life Note Book
Have you tried to remove the screw thats connected to the Video connector as well. It is a hexagon shaped screw.
Jun 04, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Samsung Galaxy Tab 2 7.0 Logo
142 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
