Question about Sony Bravia KDL-40S4100 40 in. LCD TV
I have always been able to auto re-tune my tv, but now when I try the screen just goes blank and then returns to the channel that I had the tv on, is ita fault with the tv, it is now 5 years old
6ya staff
SOURCE:
Anonymous
  • 92 Answers
SOURCE: sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
Posted on May 19, 2009
tvtek
Duke
  • 1284 Answers
SOURCE: Tv tries to power up and then shuts off, again and again.
If the fuse were to be open then you would have no lights coming on at all. These days it is very unusual to have an open fuse. You will have to have a technician look at the TV.
Posted on Sep 10, 2009
Anonymous
SOURCE: Not receiving channel 5. Cannot re-tune TV.
You can only access auto tuning by going through the digital menu via information button on remote. Pressing the menu button only brings up analogue set up.
Posted on Dec 24, 2009
Adarsh Saroj
  • 1044 Answers
SOURCE: SCreen goes blank intermittendtly
It is OK that there is enough space where your PS3 is located but what is required is ventilation to take out the heat which may be the case in this case. Therefore try to put PS3 in a place where the place gets enough ventilation. There is no other reason for screen going blank intermittently Also, it is suggested that you clean the terminals of the cables periodically by disconnecting them as the heat attracts dust and the contacts become dirty with dust thus affecting the connections
Posted on Apr 12, 2010
adnahsl
SOURCE: "Guide" button makes Sony Bravia TV go to black screen
I am having the same problem with my newish Sony Bravia. There is only a black screen when I use the "GUIDE" button. And individual channels show "No program description".
Did you ever figure out the problem?
Thanks.
Posted on Jan 05, 2011
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
Lg 26lh2000 wont auto retune, help please.
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
How I re-set the skip channels
Just do an auto tune function. Refer its user manual for details.
Sep 18, 2012 | Prima C2012 TV
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
My DTV stopped working giving a blank screen
It may just need to be Re-tuned.
What I would suggest you do is make sure that you are on a DTV channel on your Tv. then with your Pioneer remote press the menu button and then set it away on a Auto tune.
You must have it on a DTV channel first before try to tune as if you mistakenly have it on TV (terrestrail channel) It will only Auto tune that and not your freeview.
Hope you get it sorted.
Cheers Little Dish Fitter
Oct 06, 2009 | Televison & Video
32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Dec 18, 2008 | LG 32LC7D Television
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
