Dryer heats but not to full heat. Have cleaned duct.
If
your dryer
is not drying
like it once did or if you just have not taken the time to give
yourself a clean
dryer
in a long time then you need to do that. At least once a year the
dryer
cleaning
should take place. Lint
build up
in the dryer
duct
is one of the main causes for your dryer to fail.
Here is the
rest of this tip about Dryer
Maintenance
heatman101
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
