Question about Westinghouse W4207 42 in. HD-Ready LCD TV
Remove stand from w4207 TV
Am wall mounting a Westinghouse 42" TV and need to remove the stand
    Top Expert:
  • Westinghouse Master
  • 12,962 Answers
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Posted on Sep 08, 2015
6ya staff
SOURCE:
Missing stand
You can get to find alternative mounting by visiting any hardware store. Please find some tips from the link below with which it can be mounted to be fixed on the table or rack.
http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
Dec 10, 2011 | Westinghouse Computers & Internet
I have a Westinghouse SK-32H240S and my base for the tv is broken. i dont know where i can get one! i want to order a new one but dont know from what store. thanks
There are many better and cheaper stands that can make it a self mounted tv.
http://www.walmart.com/ip/Sedona-Ebony-TV-Stand-with-Mount-for-TVs-up-42/15047830
May 03, 2011 | Westinghouse SK-32H240S Television
I have a 42 in. Vizio Galleria and need to remove table top stand so I can wall mount. How do I remove base stand?
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Mar 13, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
42'' Sense LCD TV Removing the Stand
THE WAY I DO IT FOR ALL TV
usually you got 4 screw in the back of the tv need the bottom
be sure to put tv face down on your bed you gone have a surprise
gone fall from the stand
and pull it from the tv by the buttom
Mar 06, 2010 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
Stand
You should see at least 4 large phillips head or box headed screws tha hold the stand in place.
Mar 10, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Westinghouse W4207 42 in. HD-Ready LCD TV Logo
304 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
