I tried deleting an email from my Inbox under my ME MAPI account, and I got the following message: The connection to Microsoft Exchange is unavailable. Outlook must be online or connected to complete this action. My Internet connection wasn't down, but it was lagged from some network activity at the time.
- Stop the Microsoft Exchange Search Indexer service. Run Stop-Service MSExchangeSearch if you are into Shell.
- Browse to where the database files are located on the disk. Along with the database file, you will see a folder with "CatalogData-random string" as its name. Delete this folder, which stores the corrupt index.
- Restart the Microsoft Exchange Search Indexer service. Run Start-Service MSExchangeSearch if you are into Shell.
- Give it a minute and a new folder will be created and a new index will be built.
If you are still experiencing the issue after applying this fix you can try Exchange Server Repair Toolbox https://www.repairtoolbox.com/exchangeserverrepair.html
Exchange EDB Recovery is a powerful tool to repair and restore inaccessible Exchange Server mailbox and repair corrupt or inaccessible edb file. It recovers EDB files and export them into Outlook pst file. This Exchnage EDB Recovery utility can restore several mailbox items such as contacts, emails etc. it is compatible with all Exchange Server Version to recover EDB files.
SOURCE: microsoft outlook 2007 problem
also check the pop & smtp server settings or the ports used on your outlook, they must match those set by your ISP
"Scan to email" feature is dependent upon the TWAIN and MAPI supported applications. TWAIN and MAPI (Message Application Programming Interface) are standards that relate to "Scanning" and "Scan to email" features respectively. Applications have to support these to make use of HP Director. Not all email accounts are MAPI supported applications. The following are the ones which satisfy the MAPI criteria.
Microsoft Outlook Express 6
Microsoft Outlook Express 5
Microsoft Outlook Express 4
Microsoft Outlook 2000
Microsoft Outlook 98
Microsoft Outlook 97
AOL E-mail Version 8
AOL E-mail Version 5
AOL E-mail Version 4
If you are not using any of the above email accounts, you need to configure your email account with Microsoft Outlook/Outlook Express to use this feature. After configuring, you can use the scan to Email feature by perfroming the following steps.
1. Open HP Director/ HP Solution Center.
2. Click Settings -->> Scan Settings & Preferences --->> Scan to... Setup.
3. Select the available destinations and add them to the front panel destinations.
4. While scanning, you will receive a window showing the scan details which contains the section "Where do you want to scan?". Select "Email".
