It was idling fine and just as i changed gears the revs piked up instead of 800 rpm it is now between 2500 and 3000 rpm checked excel cable not sticky and is not tight idling mech smooth and also not sticky can you help? kobus
SOURCE: IT IDLES HIGH AN WONT REV UP
Change all the filters (fuel and air). check and see if all your spark plugs are firing or just change them. if it is fuel injected make sure your injectors are working. Hope something there helps get it running good.
SOURCE: Truck idles rough but at
Give it a complete tune-up, New spark plug and wire.new Ignition coil. Depending on the engine either replace ,Cap and rotors or coil packs.Also might want to get the fuel injectors service
SOURCE: high revs
being a fuel injected engine , there are many reasons this could be happening.
from the top , lets check the Manifold Absolute Pressure (M.A.P.) sensor , as it is easiest.
Find the MAP sensor , it has a couple a wires and a vacuum tube going to it and is on the firewall or fender support under the bonnet.
Disconnect the wire harness from it (small plug with wires).
If the engines RPMs drop to normal , replace the MAP sensor.
SOURCE: High Idle speed on 1989 Merc Sable, 3.0L V-6. Approx 2000 RPM
My wife had a 93 ford tempo 4 cylinder with same problem.It turned out to be the idle air solenoid mounted on the air intake manifold.
SOURCE: 1999 saturn sl1, engine revs to2500-3000 rpm when shifting gears,
I would clean the throlle body first. Then lube the throttle linkage.
