SOURCE: Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
SOURCE: My freezer door handle is coming loose. How do I
The handle should slide to the left using the handle release card
SOURCE: how do I tighten up a loose handle on the bottom
It took me a while but I finally figured it out. You need a special screw driver bit. The bit is a T10 -- it's star shaped but that is the size you need. There is a place to access this under the handles -- works great!
SOURCE: handle on bottom freezer door
Thanks to Dana; it was a 5-star screwdriver, which I was fortunate to find one in my collection of tools and solve the problem. 30 minutes to figure out it was a 5-star screwdriver and find the tool; 3 minutes to fix the handle!
SOURCE: How do I tighten the door handle on my maytag oven
Yes you need to take the inside of the door off. Usually a few screws. Then you will have access to the screws that hold the handle.
