If you mean the PC app, you have gone into full screen mode.
You should find a "< Back" link in the top left corner. Hitting that will restore your view to include a left side panel with Search, Messages and Active.
Could be a lens hood or some other attachment masking the field of view, but that would be obvious.
Otherwise, in a dust-free environment, detach the lens, use a bulb-type air-duster brush to blow the interior, as the CDS sensor may have something blocking its view.
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3Mâ„¢ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
Hi,I think the reason for that is your tv is in auto mode in aspect ratio setting. If its in auto mode it automatically fits the screen. For instance the show that you were watching prolly was not shot in widescreen mode. Try playing something that was shot in HD like some HD channel. Good luck.
640 x 480-------------7.9"x5.9" (9.9" diagonal)800 x 600-------------9.8"x7.4" (12.3" diagonal)832 x 624------------10.3"x7.7" (12.9" diagonal)1024 x 768-----------12.6"x9.5" (15.8" diagonal)1152 x 870------------14.2"x10.7 (17.8" diagonal)1280 x 960------------15.7"x11.8" (19.6" diagonal)hope this helps in setting up correctly
You will need a diagonal, eyepiece and a finder scope. The photo tripod is not the greatest for astronomy. Acceptable for the moon and quick views of the planets but with a SCTs narrow view, you will be constantly adjusting the tripod. I would start with a 25mm plossl eyepiece which would provide 80x power. About as high as you can get with a photo tripod. Places to get finder scopes, eyepieces and diagonals http://www.agenaastro.com/
Remove the eyepiece, and look down the focuser tube. The small diagonal mirror should have the full main mirror visible. If not, then adjust the diagonal mirror until all the main mirror is viaible, and the diagonal is centered. Then the main mirror is aligned until all the images viewed are concentric, with your eye being in the middle. That should do it.
Seems there is something internally wrong in your mouse or you use the mouse on a very strange material base. I have heard that optical mouses can have strange behavior when used on glass tables or thick woolen carpets, a mouse pad would solve it. If that does not work and it's still under warranty, just ask for replacement or repair.
