Question about Toshiba Televison & Video
I have a radio shack 15-302 rc and I need codes for a Toshiba DVD player and a sansui platinum plus t.v. if possible thanks
    Genius:
  • 1,554 Answers
Its not likely you'll find these codes as few ever publish them as manuals have become a thing of the past on most devices.
but you have a search function on any remote it might only give you the power on / off an if your lucky the vol control advanced functions rarely ever work on remotes unless you scan them using the original remote into the new master remote
some day i spect there to be a master site with all scanned codes for every tv etc made .. slobber
Posted on Sep 12, 2015
6ya staff
SOURCE:
Rishi Roshan Ali
  • 2427 Answers
SOURCE: sansui VCR/DVD player combo. A Platinum Plus model
It moves cause its trying to read the disk.
the two main causes of this is that
1.) the disc isnt spinning fast enough 5000rpm is required for it to work
2.) the lens is damaged
in eighter case you'll need to replace parts..
you can take it into a technician if you like of you can try to fix it our self
if it aint spinning fast enough you have to change the motor
if the motor is fine then its the lens, try cleaning it and if that dont work replace it.
I'd recommend you get a new player cause the parts required is a bit hard to find, and it cost with the technicians labour almost as much as a new one
MY SIGGESTION is its disposable
Posted on Jan 05, 2008
Anonymous
SOURCE: remote codes
Radio Shack has a website for all of it's universal remote codes for the remotes it sells at www.rcinfo.com. There you'll find what you're looking for.
Posted on Sep 11, 2008
mrfixie
  • 303 Answers
SOURCE: need a car charger for Kawasaki DVD player PVS10921
You can buy a new KAWASAKI PVS-10921 car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for KAWASAKI PVS10921 portable dvd player
Posted on Jul 05, 2009
ravichetty
RAVI CHETTY
  • 158 Answers
SOURCE: crack DVD Player
there is a disc that panasonic has to load to open region codes
Posted on Jul 20, 2009
SOURCE: i need remote control codes for a Sylvania VCR/DVD
hi! i have here a couple of codes for your sylvania DVD/VCR just try them, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095. hope this helps!!!! goodluck!!!
Posted on Jun 09, 2010
Check disc
The DVD player's laser pickup assembly is intermittent and since it is brand new and under warranty take it back for replacement. There should be no issue with your TV set.
Mar 18, 2012 | Televison & Video
Cod for poloroid tv
  • Try to use tv codes for Mitsubishi tv
  • Toshiba code 678 works for a Polaroid TV model FLM-1514B on the universal remote function of my Dishnetwork remote.
  • THE UEI TV code for polaroid tv/dvd combo is 1991. The dvd code equivalent of that code is dvd 1480.
  • Here's the technical info for each of those Polaroid TV codes.
0019 = NEC1, device code 4
0054 = RC-5, device codes 0 and 3
0150 = Mits, device code 71
0178 = NEC1, device code 4
0765 = NEC1, device code 64
1256 = NEC1, device code 64
1276 = $0057, device code 71
Feb 20, 2011 | Radio Shack 15-2200 Remote Control
What is the setup code for the DVD Video Recorder D-R410KU to control the player with the cable box remote?
I have found the code for the Toshiba D-R410 DVD recorder ! The code that works with my Radio Shack family 5 in 1 remote is:
1008
I hope this helps !
Feb 06, 2010 | Toshiba DR410 DVD Recorder
Need remote code fo tosihba d-r410
1008
I hope this helps !
Apr 04, 2009 | Toshiba DR410 DVD Recorder
MVBG45
Go to Radio Shack with your DVD player and manual if possible. They need to know the voltage and weather it is ac or dc. Radio Shack handles all types of charges ( ac adapter ), and will have the one you need.
Jan 26, 2008 | Liquid Video MVBG45 Portable DVD Player
Codes for a coby dvd player
I sucessfully programed the AUX button on my Cable remote to my Coby DVD player (model DVD-227) using code 21107. You can also try these codes: 20778, 21086, 21351.
I hope that helps!
Nov 01, 2007 | Radio Shack 15-2104 Remote Control
Remote control #15-2147
Toshiba 0749, 1749, 0790, 1285
If that doesn't work then:
If your device does not respond to the remote after
trying all codes listed for your brand, or if your brand
is not listed, try searching for your code. For example,
to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks twice,
then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The
remote sends IR codes from its library to the
selected device, starting with the most popular
code first.
5. If the TV responds, go to step 6. If the TV does
not respond, press CH+. The remote will try the
next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps 1
to 6, substituting the appropriate key for the
device.
IF that doesn't work, I know a great place to find sledge hammers.
Oct 04, 2007 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
