Question about Behringer XENYX 2442FX Mixer
Why is there a popping sound and noise on behringer xenyx 2442fx after a while and no sound
6ya staff
SOURCE:
Fred Yearian
  • 5603 Answers
SOURCE: Connect xenyx 2442fx to computer
If you want to record in stereo, the quick and dirty way is to get a 1/4 inch stereo to 1/8 inch plug cable and go frrom the headphone output jack. (Use a Wye connector if you need to listen on the phones)
All the other outs are TRS and XLR balanced and the computer audio (mic) inputs are unbalanced. You would need special cables to connect those.
Posted on Feb 08, 2010
Fred Yearian
  • 5603 Answers
SOURCE: Behringer XENYX 2442FX Mixer. The power light
You have likely lost one, probably the +15 volt power supply... This is possibly a shorted component or a short on the circuit board causing this. It takes some skills at troubleshooting to find this. Sometimes using a thermal imaging camera will show hot spot... other times you have to search with a millivoltmeter. The rude solo light is driven by an op amp that uses both polarities of 15 volts and to turn it on it pulls negative... Hence I suspect the +15 is missing.
Posted on Nov 06, 2010
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: how do i hook up a powered moniter to the
hook it up to one of the aux output sends (1 or 2), and use the corresponding aux send knob per channel to put each channel necesarry into the monitor signal.
Posted on Nov 30, 2010
Fred Yearian
  • 5603 Answers
SOURCE: behringer xenyx 2442fx : I need to know the
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Posted on Feb 13, 2011
Testimonial: "Really great help ! Thanks once more !"
mrwtech727
mrwtech727
  • 75 Answers
SOURCE: how to connect a Behringer XENYX 2442FX Mixer to a
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
Posted on Sep 01, 2011
I am trying to record from xenyx 2442fx to audacity. I am not sure how. I think it has something to do with usb, but do not know how to connect the mixer to the computer to get a good sound. Please help.
First, connect the USB audio interface which came with the Xenyx to a USB port on the PC. Then connect the TAPE OUT from the Xenyx to the IN of the USB audio interface. And connect the OUT of the USB audio interface to the TAPE IN of the Xenyx. You should now be able to record from any of the Xenyx channels. To listen back, engage the control room button which reads CD/TAPE. Contact me if you need any clarification.
Sep 06, 2011 | Behringer XENYX 2442FX Mixer
How to connect a Behringer XENYX 2442FX Mixer to a laptop
Aug 30, 2011 | Behringer XENYX 2442FX Mixer
My Behringer Xenyx 2442Fx does not get power.I have checked the power cable also.Kindly help me out
The switching power supply has probably failed. See if you can get a number off the power supply board like SPS400 or similar. Unless you are electronically adept this is lkely NOT a DIY repair.
Jul 26, 2011 | Behringer XENYX 2442FX Mixer
COMPRE UNA 2442FX BEHRINGER Y PRODUCE RUIDOS POR ALGUNOS CANALES A VECES SUENAN UNOS Y OTROS NO, ES PROBLEMATICA TENGO 15 DIAS QUE LA COMPRE Y CREO QUE ME EMBARQUE
Noise problems are often due to poor grounding or failure to use balanced audio cables. Power ALL interconnected equipment from teh SAME receptacle or source.
Dec 27, 2010 | Behringer XENYX 2442FX Mixer
How do i hook up a powered moniter to the behringer xenyx 2442fx mixer?
Nov 20, 2010 | Behringer XENYX 2442FX Mixer
I have a Tascam US1641 USB interface and wanted to know if you can connect a Behringer 2442fx to it to use it as a mixdown control for my music in Cubase studio5.
The 2442FX has a built in usb interface so there is really no need to use the Tascam. Here is a link for you:http://www.behringer.nl/EN/Products/2442FX.aspx
Oct 19, 2010 | Behringer XENYX 2442FX Mixer
Behringer XENYX 2442FX Mixer Logo
182 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Chickenwatt
Level 1 Expert
Ric Weide
Ric Weide
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
