Question about Loewe Aconda ACO9383 38" TV
Picture is distorted, enlarged, and bowed at the edges.
    Top Expert:
  • Loewe Master
  • 76,204 Answers
Pin-cushion distortion. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Sep 14, 2015
6ya staff
SOURCE:
How do you enlarge copies on the hp 8500 printer
From The HP 8500 Manual
TIP:You can also use Fit to Page to enlarge a small photo to fit within the
printable area of a full-size page. In order to do this without changing the
proportions of the original or cropping the edges, the device might leave an uneven
amount of white space around the edges of the paper.
Oct 01, 2012 | HEWLETT-PACKARD 8500 Wireless All-In-One...
Cannot zoom in a picture. When I enlarge it it is
Are you using the optical zoom or the digital zoom? digital zoom only enlarges the pixels and eventually distorts the picture. Optical zoom actually brings the subject closer.
Apr 27, 2010 | Cameras
The picture is bowed and has a rainbow affect around the edges
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 01, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a Mitsubishi projection T.V that turns off after I turn it on. Before this started happening the edges of the screen would look bowed like 3-D. Can you help to tell what is wrong and how to fix it?
Projection sets have two very common problems outlined below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Nov 12, 2009 | Mitsubishi WS-55807 TV
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
Screen distortion
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 16, 2007 | Hitachi 60UX58B 60" Rear Projection...
Edges of Picture & Text Sloping
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Jun 26, 2006 | Akai CFT2490 24" TV
Televison & Video Logo
64 people viewed this question
Top Loewe Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
