Question about Apple iPad Air
How do I reset my Apple ID and password on my apple iPad Air without boot disc or iCloud password
I have new apple iPad Air set up the administrator Apple ID and password and I forgot the password how do I reset it so I can get some use out of this thing I can't sign on to iTunes or anything ,what can I do and what r my options.?
    New Friend:
    Problem Solver:
  • 9 Answers
Follow these steps to reset your forgotten Apple ID password: https://support.apple.com/zh-cn/HT5787
Posted on Sep 14, 2015
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Mar 19, 2017 | Apple iPad Tablets & eReaders
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
Jan 01, 2017 | Apple Tablets & eReaders
How to factory rest ipad mini with out using the apple I'd or password
Connect it to a computer with iTunes. Set up your own Apple ID and Password. Then Reset the iPad.
You can also do it from the iPad itself Settings - General and at the very bottom command RESET.
After the reset you will be able to set it up from new.
Please note that the RESET command clears EVERYTHING off the device.
May 08, 2016 | Apple iPad Mini
Remove iCloud lock from iPad
I am not aware of an ' iCloud Lock '. If you mean the user set passcode, the only way is to do a Factory Reset.
iCloud has a password, and that is the same one you use at the App Store. That has to remain in place to protect your credit card use. If you have forgotten that password, you can click Forgot Password link and a reset will be emailed to the email address associated with your iCloud/iStore account.
May 03, 2016 | Apple iPad 4th generation
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Feb 15, 2016 | Apple iPad 32 GB WiFi Tablet PC
How do I reset my Apple ID?
Follow the following steps:
  1. Tap Settings > iCloud on your iOS device. If you see the option to sign in, you can change your Apple ID now.
  2. Scroll down and tap Sign Out. ...
  3. Choose Keep on My iPhone or Delete from My iPhone.
  4. Enter your password.
  5. Go to Settings > iCloud and enter your New Apple ID and password.
  6. Tap Sign In.
If you need need to reset the password, navigate to the follow link and click 'Reset your password': https://appleid.apple.com
Sep 27, 2015 | Apple Tablets & eReaders
How do I sin out of my iPad my iPad won't let me
Understand that all the apps and data on the iPad are associated with an Apple ID so "signing out" of your iPad may render some apps and functions useless.
If you are looking to sell your iPad its best to plug it into a computer and restore factory defaults. This will remove all apps and IDs associated with your iPad.
If you are simply looking for security and worry that while signed into your Apple ID there is a chance for fraudulent downloads and purchases it would be my recommendation to set a password/passcode for the iPad that only you know. This will prevent other users form gaining access to your data without your permission.
The iPad is not meant to sign in and sign out at will but if you need to sign out and add another Apple ID then here are the steps to do so.
There are 2 places in which your Apple ID are linked with your iPad. Your iCloud account (photos/documents/ID) and iTunes (music/movies/apps)
You can adjust settings for these individually under Settings > iCloud and Settings > iTunes & App Store
Simply click on the Apple ID email and then choose "Sign Out"
REMEMEBER, some apps and functions may not work without an associated Apple ID registered with the iPad.
Apr 11, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad Air Logo
286 people viewed this question
Top Apple Tablets & eReaders Experts
 Larry
Larry
john smith
gaucherre
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
