At end of cycle, if I turn the drum manually, it turns fine but it makes a noise as if something was rubbing on the drum. Any ideas?
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
SOURCE: Miele W1903 washer skipping steps (not fully draining?)
check the motor brushes could be worn out
SOURCE: miele w 427 not pushing out the water after the wash cycle
the drain pump may be blocked by a piece of debris - clean the filter out on the lower front of the machine and check for a obstacle blocking the pump.
SOURCE: Smoke in drum on spin cycle
I did it by going to an agent, I do not trust you,,,how do I know that your services are for real? Please do not be offended.
SOURCE: when I use my washing machine it stop at the
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
SOURCE: Miele Novotronic W828 Water Control System Front Load Washer
Hello Ellen, welcome to fixya. I would begin by removing the rear panel and checking the belt and insure the basket pulley isn't loose as well. If the belt is in tack ( not broke ) but has come off that sometimes is caused by a loose or bent pulley, hence the suggestion to check the pulley. If the belt is broke, it may simply be a matter of normal "wear & tear" and just time to replace it. Hope that helps point you in the right direction. Please take a moment and rate this info according to it's helpfulness or let me know if I can assist you further. Thanks for visiting "fixya" today and good luck. Macmarkus :)
