well 1st not all machines are made to be a continuous drain type , if so your machine would have come with instructions on how to convert it over for this function , aside from that a little low tech approach to this (not too great looking though) is to drill /melt a hole into drain bucket just big enough to allow a hose bulk head fitting to be screwed into it (hardware store item) and use a simple garden hose for the drain connection
sounds to me that there might be a problem in the "Tilt" sensor this sensor stops the machine if it detects a rocking machine thats out of ballance , so it wont tip over , ck level of machine with a bubble level
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
If the float switch is indicating a full drain pan, the light will be on and the compressor and fan will not run. Make sure the dehumidifier is installed level and the condensate drain is open allowing the drain pan to empty. Next check that the float is free to move up and down and the switch operates a required. Call the manufacturer at 1-800-533-7533 for parts and instructions if there is a problem wirh the float switch.
You will need to use a drain hose that is no longer than 5 feet. Using a hose relies entirely on gravity. So, the hose must slope downward with no kinks. A short 5' section of Garden Hose works well. The female coupling end attaches to the dehumidifier. It's a very effective way, not to having to stop and drain the tank time it's full.
The ADEW50LP, is a low Temperature Unit, which designed for basement applications. The ADER50LP, is a standard unit. Used for all applications, other than a basement. Both have the external drain feature and the same water extraction capacity.
