Richard nana asumadu Posted on Sep 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My office photo copier has turned from A4 to A3,changing it back to A4 has been a problem..what do i do?
Bill Boyd
Level 3:
Top Expert:
  • Office Equip... Master 53,816 Answers
  • Posted on Sep 16, 2015
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11946723
Points
172802
Go into printer options and set on a4 then set as default
Canon imageRUNNER IR 6570. Help me please! I have copier machine canon ir6570. The problem is I can't change tray No. 4 to A4R or A3 paper size, it only detected as Legal size.
question edited for clarity and toss in some CAPS.
It doesn't take A3 Paper and doesn't have a Tray No. 4.
A4R is just A4 in Landscape Mode, half an A3.
What is A4 and A4R?
The "R" indicates that the paper is set in the landscape orientation. Paper that can be set either in the portrait or landscape orientation. Paper that can only be set in the landscape orientation. 8-1/2" × 11" A4, B5. 12" × 18", 11" × 17", 8-1/2" × 14", 8-1/2" × 13", A3W, A3, B4.
Tray Capacity No-collate Mode Tray A: 250 Sheets (Letter, Statement-R, Executive) 125 Sheets (Legal, Letter-R, 11" x 17")
Tray B: 1,300 Sheets (Letter, Statement-R, Executive) 650 Sheets (Legal, Letter-R, 11" x 17") Tray C: 2,450 Sheets (Letter, Executive) 1,700 Sheets (Statement-R) 650 Sheets (Legal, Letter-R, 11" x 17") Collate and Group Mode Tray B: 1,300 Sheets (Letter, Executive) 650 Sheets (Legal, Letter-R, 11" x 17")
Tray C: 1,700 Sheets (Letter, Executive) 650 Sheets (Legal, Letter-R, 11" x 17")
Staple Mode Tray B/C: 1,300 Sheets/100 Sets (Letter, Executive) 650 Sheets/
https://copiersonsale.com/wp-content/uploads/brochures/Canon-imageRUNNER-6570-Brochure.pdf
https://www.google.com/search?q=canon+ir6570+paper+size
Changing Tray Size Settings
https://www.google.com/search?q=canon+ir6570+change+paper+tray+size
My canon ir 3320i copier toner is leaking from drum unit fix it
Can u plz Check Cleaning Blade and Mylar sheet for cut,
Check Charge Roller if gone bad.
if both seems to be ok, then change Drum Unit .
How can I change the paper size( from A3 to A4) without changing the drawer
on the drawer you need to set the paper wide sensor ( blue handle ) must be on A4, also you need to put back rails and stopper in A4 position.
Hope that helps!
1helpful
2answers
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
2answers
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
How to set the paper size in the trays?
most are set by the trays itself, when you adjust the "guides" that go against the paper it adjust some levers on the side or back of the tray which push on some sensors behind the tray.
Some however you need to turn a dial in the tray to the paper size you need.
make sure the guides are snug against the paper, the dial or settings are correct and that there is no paper behind the tray.
Also I'm not sure what country you are from but in the US we do not use A4
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
k24674
ADMIN Andrew
ADMIN Andrew
