On some Bosch models, E00 indicates that the machine is overloaded. Alternatively, the load is too heavy when wet. The machine can't safely spin the load. You may need to take this blanket to a laundry mat and use their commercial size washer.
Try running the washer when empty. If the error recurs, then the problem isn't the blanket. Instead, the motor is working too hard to spin the tub. This could indicate a problem with the motor or the pulley and hub that connect the tub to the motor.
error E:00 in Bosch
Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
If you are getting error code E00, it usually indicates that your washer is experiencing a generic error. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code
As you said in the question you are washing machine is showing the error code as E2 is nothing but Error signal due to long heating.If you want to get repair means you just need to contact you are nearest service center for service engineer.Thanks for your question.
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
