I have an INsignia NS-LCD26A that has scrambled screens with horizontal lines on startup, other times it has a locked up no signal screen that will freeze and unfreeze. This horizontal lines only appear intermittently so I dont know if this could be a bad panel, I was told a Tcon board but I am reluctant to go replacing things if I am not sure. I have pictures of the screens if it helps.
SOURCE: Insignia LCD TV 26" Colored Streaks/No Picture
You have a bad LCD panel. The cost of a repair would exceed the value of the unit. Panel will probably cost, if you could find one, around $300-$800.
SOURCE: 26'' Insignia Startup Screen
This problem requires a service technician to check out you television for component failures on the power supply board and the main board. You have a failure in either drive voltage to power you video processor or a break down in the signal transferring components.It could be as simple as cold solder joints or a failure of capacitors in the signal processing circuits. They have a self healing components and will restore temporary operation for short periods of time.You could also have a failing video processor chip and chips that are being damaged everytime you turn your unit on.. These problems usually occurs from over heating going on inside you television. You need to get it checked out before it get worse.Here is the number for Insignia Customer service: 1-877-467-4289. Hope this helps you with your problem.
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
SOURCE: Insignia NS-LCD26A 'No Signal'
What we di is as follows: Switch off the STB from its switch (not the remote). Remove the power plug from the socket on the wall. Let it remain switched of for about a minute. Plugin again and poweron with the switch on the STB. generally it works after this exercise.
SOURCE: Insignia 32" NS 32 q09
Since you don't mention how you're receiving the signal, I'm assuming you use a cable box or computer. Adjust the output settings (e.g. 720p, 1080p) on the box and then adjust your TV settings. If it's a computer, you'll need to adjust the video card settings to a compatible aspect ratio (e.g. 1366x768) for the desktop to display properly on the TV. Details can be found in the owner's manual.
