And how do u do it. thanks
From remote setup, 5 4 3 2 1 0(hold "0" for 4 seconds) let go. look for the brake override option and turn it on.
I have a phase linear indash and the remote dont work i even got a new battery and still nothing can anybody help me please
Hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done
Ok this is very easy
1. have your player on radio (am/fm)
2. go to settings (must have a remote)
3. click the language button (next step is where you need the remote)
4. type in the following numbers 543210 (make sure you hear the beep)
5. a new menu appers after the code (hard-drive)
6. click on the break-bypass button
7. turn on the bypass
8. click the x on the bottom of screen
9. your all set now you have your player unlocked so you dont need the parking break
10. REMEMBER SAFETY IS FIRST PLEASE BE VERY CAREFUL WHEN USING THIS UNIT PAY ATTENTION TO THE ROAD AND NOT THE PLAYER YOUR LIFE IS MORE IMPORTANT THEN THIS DEVICE
Ok thanks that helped and it was simple you guys Rock!!!!:-) And I am a girl and never do technical stuff like this I was looking for someone to charge me for this.
Look the pink wire you must to conect with the black wire(-) if you wants you can put those togheter,and after that with the remote control go to dvd set up,don't touch anything,on the remote control press this numbers,5,4,3,2,1,0 and going to appears like four squares ok, and you have to go to the 2nd after that you will see one square say's (off) touch that and put that on (on) and your work is "DONE"
mire el cable rosa que dice(parking break) usted debera conectarlo con el cable negro (-) si usted quiere puede concetarlos juntos, el estereo despues de prenderlo tiene que esta en el radio pongalo en cualquier estacion de radio,y despues con el control vaya al DVD SET UP, no toce nada,con el control presione, 5,4,3,2,1,0 y aparece como cuatro cuadros ok,y usted tiene que ir al 2o después,usted verá un recuadro que dice (off) sellecione ese ya sea tocando la pantalla o dandole play con el control remoto pongalo en (on) y ya,se sale yahora ya puede ver sus videos favoritos ya es todo ojala que lo pueda entender es muy facil buena suerte
You guys i need help on my Jensen uv8 , i have done the by pass for the break , but now the remote is not working please helppp
It was good I wonder if i can install a new program like gps to it will be good.
Setup button on Phase linear remote works this way.
first you hook up the ground with the pink and when you are in am/fm mode hit the
dvd set up button on the remote, input the number 5, 4, 3, 2, 1, and 0
make sure it beeps after every number. has been pressed. then it should
this works I telling you it works!!!!!!!!!!!!!!!!!!
Yes always go to fixya first
Also if you dont have the remote you can hook up the pink wire ( the ground that goes to the brake, to the regular ground as well as the black (the regular ground) and it will act like the brake is always on and you never have to worry about any codes
Thanks for helped
I hatte my ******* jensen it sucks
Bad *** ,Was about to pay $5 for the Brake Bypass Code on ebay
thanks
Is the remote a must? I can not find mine.
Why does it my phase linear dnt lets me play the ipod can it be the axe in 1?
Dvd will not load
518lou has the rite procedure it took me like three minutes to do and it works great thanks and e bay tried to charge me too.
I need the code
My UV8 power turns off at random times. It will not memorize the channels set.
Umm i dont have the remote is there a another way to go around that?
Thanks man that code did the trick....
Pongalo en español xD...y si me lo pueden explicar bien porque ya lo e intentado en mi stereo y no funciona. les agradesco GRACIAS!
This worked out perfect for me. I hit the setup button, entered 5,4,3,2,1,0 (I made sure it beeped for each number entry) then the hidden menu screen came up. I changed it so that it will bypass the break.
You guys rock...I installed the unit today without a hick-up...
Thank you
Guys i cant get this uv8 bypassed is there a new way?
Ground out the pink wire
You guys rock! i work at circuit city and this saved me a bunch of time on the display (we actually ran out of toggle switches). again, thanks!
Hit setup first from the remote and then 543210and hold 0
Put a dvd in first and do the setup 543210 code.
How do i over ride the park brake pink cable on my phase linear uv8?
how to braek the code of my phase linear UV8 please.
tried this cannot get off of "blue screen of death",do i need pink wire attached to something
i dont have a remote control to use the bypass code on my stereo...do i really need it????
How do you bypass the Vm 9212 model jensen??
ive hookd up the harness correctly sound plays but the screen stays blue
j cant get passed the uv8 security code
i hooked up the neg. side of 3.0 vdc to the pink parking brake lead of the head unit .but i still do not have video,but ido have all other funtions & audio.
i cant get past my code.
anyone got the code please help
the aux 1 wont play my ipod
lost my remote dont know how im gona put in the codes.any way to ground it or something..used to have it in my chevy tracker and i spliced the brake sensor wire and attached the pink wire to it and then put it in neutral then back to park and it worked most of the time.but know ive installed it in my 94 mx-3 precidia and ive attached the pink wire to e brake wire and still that dang blue screen..any body know where the e brake reley is on a 94 mx-3??????????????????????????????????????????help me??????????????????????/stupid F****** blue SCREEN GO AWAY///??????????????????????????????????????????/
i'm trying to put in my phase liner uv8 and i need the bypass code to get it to play if someone can help me please answer
i lost the remote to my jensen and grounding the pink wire dosent work ! how can i make my video option play without putting in the code!
lost remote and i need to know how to bypass the wire to make the tv play while driving
I dont have remote for my phase linear. Can I bypass the brake system ? if so H.O.W ??
I dont have remote for my phase linear. Please tell me its possible to bypass the parking brake system , If you can. H.O.W ??
is there a way to bypass without using the remote?
