Question about Proscan PLT 9 TAB 9-Inch Tablet Black
How do I access the microSD card? - Proscan PLT 9 TAB 9-Inch Tablet Black
  • Proscan Master
  • 4,290 Answers
Anonymous
SOURCE:
How to put microsd card in yuntab 10 inch tablet
First is to check whether your tab has a 'microSD port' or not.
It might not be noticeable when you check on the body/edges/outer frame of your tab otherwise you won't be asking this question.
In this case, you may need to open the back cover of your tab (there has to be say a small part you can readily open to access the microSD port inside your tab).
Where none exists, probably, your tab does not support microSD card insertion.
Sep 30, 2017 | Tablets & eReaders
Samsung tab 3. Tell me About it and what it is worth?
New, $175. Used. $70.
  • Android 4.1.2 Jelly Bean OS, 1.2 GHz dual-core processor
  • 8 GB Flash Memory, 1 GB RAM Memory
  • Store photos, videos, music, and more with up to 64GB of memory available through a microSD slot and 50GB of free Dropbox storage
  • Camera: 3MP rear-facing, 1.3MP front-facing
You might be able to upgrade the OS to KitKat 4.4 but are unlikely to be able to update it beyond. However, whatever gains you get in performance will pale next to sudden restrictions you find on SD card access. Android Central has users up in arms about SD card issues regarding the KitKat and Samsung. If the apps you like run under JellyBean, I'd not bother to update the OS. Other may choose to root the device.
Sep 03, 2017 | Samsung Tablets & eReaders
Reset asus memo pad kow to factory settings?
If you cant reset your phone normally try hard resetting it.
  1. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  2. Afterwards unzip it to your MicroSD card.
  3. In order to turn the device off press the Power button for a short while.
  4. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  5. Afterwards unzip it to your MicroSD card.
  6. In order to turn the device off press the Power button for a short while.
  7. Select Clear User Data using the Volume buttons to navigate and Power key to select.
  8. When "Please remove installation media!" inforamtion appears on the screen remove the microSD card from your device.
  9. Success! The hard reset has just been performed.
If this doesn't work use the link below
ASUS ME176C Memo Pad 7 How to Hard Reset my phone HardReset info
Mar 17, 2017 | ASUS Tablets & eReaders
I have two Amazon Fire HD Tablets at capacity storage - they do not have a memory card port. What can I do to increase the memory on these tablets.
You can buy a HooToo. It is a little box that created its own wifi between the box and the tablet. It is not a hotspot to use for surfing. It will hold up to a 128Gb Micro SD card and up to 5 tablets can access the content at one time. Check them out on Amazon, they work well up to about 30 feet for the HooToo. So 5 kids can be in the car all watching different movies.
Jan 17, 2017 | Amazon Kindle
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
Cant access fb or play card games could this morning
RCA 7" Tablet 8GB Quad Core - Walmart.com
www.walmart.com/ip/RCA-7-Tablet-8GB-Quad.../38693696
Walmart
Rating: 2.5 - ‎233 votes
Buy RCA 7" Tablet 8GB Quad Core at Walmart.com. ... RCA 7" Tablet 16GB Quad Core .... stereo headphone jack; 8GB onboard storage memory, additional memory via microSD card slot ... Due to federal restrictions, this item cannot be returned by mail..... A. You can save music on here and play games from the app store.
RCA 7" Tablet 4GB Memory - Walmart.com
www.walmart.com/ip/RCA-7-Tablet-4GB-Memory/28458515
Walmart
Rating: 3.5 - ‎611 votes
Buy RCA 7" Tablet 4GB Memory at Walmart.com. ... read eBooks, view photos, play games, listen to music and watch video files. ... Cannot return by mail ... does not have a credit card and I do not want him to have permanent access to mine, ..... About Our Ads · Affiliate Program · Sponsorship Requests · CA Privacy Policy ...Missing: fb
RCA 7 Inch Tablet: After 4 Months - YouTube
? 5:11
https://www.youtube.com/watch?v=bNA2XaR_Yc0
Mar 22, 2014 - Uploaded by Underground Tech
Reviewed the newer version of the tablet and discussed BATTERY ISSUES: ... you can play Pokemon on here .... thistablet also cannot transfer files or cancel active downloads. those... Can the sd card extension actually hold apps on it? .... HP Envy 15.6" Laptop Gaming Performance [A10-5750M][AMD ...Missing: access ‎fb
Customer Reviews: Proscan 7-Inch Android
Jan 13, 2016 | RCA CA 7" Tablet with 4GB eory 28458515
My grandpa bought a RCA for me to put all his songs on it. And they are all on the computer and i dont know how to transfer them
There are two ways:
  • From computer. Use micro USB cable,connect it to tablet. Computer will detect the tablet as storage device. Open explorer. Copy your files from computer to tablet in the folder where you want to store/save.
  • Use micro SD card. Insert microSD card to computer/laptop. Copy your files to microSD card. Remove microSD card. Insert it on your tablet. Access the files. To access files on microSD card, you can see on this video :
Video is courtessy of Youtube - RCA.
You also can use flashdisk as a files transfer storage.
If using flashdisk,transfer procedur is same as for microSD.
If using flashdisk,you need miniUSB to USB adapter. See photo:25848604-tr0bbbe1g5ua2mps4ks3loyz-2-3.jpg
I hope this help.
Regards.
Sep 03, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How do you put a microsdhc card in a noble tablet
You can add a properly formatted microSD card inside the rear of the device:
  • Power off your Nook, unplug from power, and disconnect it from any USB connection.
  • Place it face down on a kitchen towel (so it won't get scratched).
  • Find the tab near the center of the bottom of the back cover.
  • Lift the tab (gently)and open the back. Note that the cover is snapped-in at the bottom, the middle and the top. Unsnap the cover carefully.
  • Identify and open the microSD slot cover with a fingernail, not a screwdriver!
  • Drop the microSD card into place, while lining up the contacts.
  • Close and then lock the card holder.
  • Replace the back cover onto the Nook
  • Snap the sides into place,and close the tab.
  • Power up and enjoy
NOTE: the card needs to be formatted using FAT32 or FAT16 not NTFS!
Jan 04, 2015 | Tablets & eReaders
Is it possible to transfer pictures from a memory card to the surface rt tablet
Use either microSD card (Surface has a slot for this card), or SD card with USB adapter. This way it is easy to transfer pictures .
Oct 14, 2014 | Microsoft Surface RT
I have an Acer Iconia Tab A500. It is telling me my storage is low. I guess I need a memory card, but what kind...how much storage,etc. Help...I am technology challenged! Lol
Acer Iconia Tab A500 has 16384 MB of Builtin memory. There is a plastic flap right next to the buttons, where you can insert a microSD card.
You can add microSD, microSDHC Card of up to 64 GB MAX
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 08, 2011 | Tablets & eReaders
Proscan PLT 9 TAB 9-Inch Tablet Black Logo
91 people viewed this question
Top Proscan Tablets & eReaders Experts
Harrie
Ngoro
rostit
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
