BT Synergy 6500 Cordless Phone - DECT - Silver Titanium 1 x Phone Line - Answering Machine - Caller ID - Speakerphone - Backlight Logo
J
Joyce Newberry Posted on Sep 21, 2015
Handset will not register to base
Followed registration sequence but get message - registration failed
1 Related Answer
mbarre
  • 937 Answers
  • Posted on Jan 08, 2015
SOURCE: how do i register synergy handset to freestyle base
See if this helps:
Uniden D3098S I have 2 register hand sets #1 and #2 I have a 3rd one having trouble registerting it to the base iam 2 feet away from the base unit it says check base power & out of range
Registering a Handset
If you see a "not registered" message on a handset, you must register it to a base before using it.
1. On the base, open the menu and select "Register Handset"
2. On the handset, press and hold POUND (#) until the handset display says "Handset Registering" (about 2 seconds).
3. Wait until the handset display says "Registration Complete" (about 30 seconds), then pick up the handset and press eND/CleaR.
# If you don't hear a dial tone or the display says "Registration Failed" charge the battery completely, then try again.
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
1.
Register Accy.
2.
On the handset, press and hold #/DND
Handset Registering (about 2 seconds).
3.
Registration Complete (about 30 seconds),
then pick up the handset.
Registration Failed, charge the battery completely,
then try again.
Binatone 1910 flashing not registered to base
Registration:
Instructions if you need to register handsets to the base:
You can register additional handsets to have up to five handsets per base unit, with each handset's number (1 to 5) shown on its display.
1. Press and hold <PAGE> on the base station for more than five seconds to put the base station into registration mode. (Note: there is no feedback to know it is in reg mode.) It will stay in registration mode for about 1 minute. So complete following sequence within this time. (It helps if handset is kept very near to the base during this).
2. Press <MENU> and <UP/DOWN> on the handset to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING. If the handset registration is successful, you will hear a confirmation tone and the <antenna icon> will stop flashing. This may take a short while. The handset will automatically be allocated the next available handset number. This handset number is shown in the handset display in standby mode. If thehandset registration is unsuccessful, the <antenna icon> will still flash and the display will return to ' REGISTER', so you will need to repeat registration process.
I cant dial out it says register HS i am not familiar with the procedure.
When you reset a handset (or if you buy a new one1, that handset displays a Handset Not Registered message. If you see this message on a handset, you need to register it to a base before you can use it.
Does the handset fit in the base cradle?
Yes
No
Place the handset in the base.
The display should say Handset Registering.
1. On the base, open the menu and select Register Handset. The display should say Handset Registering.
2. On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
In about 30 seconds, the handset display should say Registration Complete. Press TALK ( )/FLASh and make sure you get a dial tone. page29image32024
27
If...
Try...
- you don't hear a dial tone- the display says Registration Failed
Making sure the handset is fully charged, then start over at step 1.
To register a handset to a different base, see the section "Expanding Your phone" in the user's guide for the other base.
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
Out of range or no pwr at base
It sounds like the handset has "lost" its registration with the
base ( or a replacement handset is being introduced ? )
Either way, the handset displaying "Out of range..." is now
orphaned and must be deregistered and then re-registered
to the new/current base.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734# (menu)
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
5helpful
I have a Eurotel E1110 device but it is asking me to register the third phone again. I do not know the pin-number so what can I do?
7.5 Registration
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Can't register new handsets
with in this time.
Hope this helps you
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
Jesse Walters
Jesse Walters
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
