Golds Gym Trainer 410 Treadmill Logo
L
LaTasha Faircloth Posted on Sep 24, 2015
Treadmill starts moving up and down when key is on. How to fix?
Mary E Washington
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 23, 2017
Mary E Washington
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
632
Points
This happened to me as well. As wierd as this sounds, Rub/Massage all of your console keys well because believe it or not, they get stuck. While unplugged and without the magnetic key "inserted". Plug the machine back in and "insert" the key. Allow the machine to do the full incline and decline sequence if it decides to do so. Once this happens the machine should allow you to work the console buttons without any issues. At least this is how I was able to fix mine while on the phone with the Gold's Gym technical support. Hope it helps.
  • Bethany Still
    Bethany Still Feb 06, 2018
    This was very helpful. I was freaking out because I moved my treadmill this weekend and when I plugged it back in and inserted the key, it just started making noise. I thought it was broken. I had no idea that it would attempt a full incline/decline sequence. Once I realized that's what it was doing, I let it finish and it was good to go! Scared the hell out of me! Thanks!
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
1helpful
Unit immoblize
reset the machine follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
    • 3
    • 4
    • 2
I bought a elite saracen treadmill n it says error code 4 what does that mean please n e wun help me pliz
reset the treadmills, follow this steps and fix it. GOD BLESS YOU
However you must RUN the software calibration for fix it. see your owner manual. or download free from www. fitness.manualsonline.com
    • 1
    • 3
    • 4
    • 2
GOD BLESS YOU
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
My facebook, firefox. youtube all are not loading correctly. the script is on the left side of page with nothing in middle. Has little links and blocks all crowded to gether and everything is messed up....
RESET THE machine, follow this steps and fix it. God bless you
      • 3
      • 4
      • 2
    When turn it on just beeping noise
    reset the treadmill. follow this steps and fix it. God bless you
    1.
      • 1
      • 3
      • 4
      • 2
    Bad relay message and circuit breaker is pushed in and stuck
    reset the machine and follow the step and fix it.
      • 1
      • 3
      • 4
      • 2
    After attaching key all lighs come on but none of the buttons work except foe pulse feature. also belt won't move.
    rests the treadmills, follow this steps and fix it. God bless you
    replace old batteries ( if your system has batteries, clean the contacts batteries from oxide, dirty, etc) put a new one. Tight the ribbon cable inside the display board+tight the upper and lower connector too.
      • 1
      • 3
      • 4
      • 2
    I have a pro fitness folding treadmill. It shows 'er 3' in the time box. Is there an easy fix for this?
    reset and restart. God bless you
    Instructions 1.
      • 1
    Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
      • 2
    Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
      • 3
      • 4
    Top Golds Gym Exercise & Fitness Experts
    Sportsmith LLC
    Sportsmith LLC
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
