SOURCE: Changing the coordinates of the autostar for meade etx 125
What are you using as a reference for "LST time"? I assume you're aware
that stands for "Local Sidereal Time", and not Local Standard Time; some
folks have confused the two. Do you have another method to calculate
Sidereal time for your location?
When you set Date and Time in the Setup menu, you need to use the time
from the "clock on the wall" without any mental adjustments for Daylight
Saving or Time Zone; those settings are made elsewhere. From your
description of the problem, it sounds like you have a time offset,
especially if your Site location values are fairly accurate.
Whether you use Zip Code or City sometimes depends on where you live
with respect to a particular city. If you live several miles from the
nearest city, Zip Code may be best .
SOURCE: MEADE ETX 125 Motors have stopped
The ETX125 is notorious for bad motor control. Weasner's Mighty ETX web site has links to repair centers that are more reasonable than Meade. They also have a QA section to assist with diagnostics.
SOURCE: Meade ETX 70 telescope won't turn on regardless of power source
Dead on arrival!
Meade can fix these, but they must be shipped back to the factory.
Here is their customer service web site:
http://www.meade.com/support/index.html
SOURCE: Meade ETX-60 Horizontal drive
The AZ worm gear is not engaging the gears. There is a spring next to the gear which applies pressure -- open up the base and see if the spring is loose or broken.
SOURCE: The declination knob on my
There are some possible repairs. Go to the Mighty ETX web site and search for DEC KNOB repair.
http://www.weasner.com/etx/menu.html
