Adeola Adeniyi Posted on Sep 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Jeff Watkins
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 33 Answers
  • Posted on Oct 25, 2015
Jeff Watkins
Expert
Level 2:
New Friend:
Night Owl:
Answers
33
Questions
Helped
15833
Points
165
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
5 Related Answers
Anonymous
  • Posted on Nov 03, 2008
SOURCE: E7 problem
Sharp AR-5132 won't print
Error code E7 13
It will warm up like it's about to print or scan then error code E7 13
please give any advice
Everett Lin
  • 990 Answers
  • Posted on Apr 28, 2009
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Anonymous
  • Posted on Jun 06, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Aug 13, 2009
SOURCE: My Photocopier displayed error H4 on the screen
Dear sir
H4 signal is fuser unite problem please call a technician they solve this problem.Just we serve problem location because i am not live your area.
Thanks
Tareq
Anonymous
  • Posted on Jan 23, 2010
SOURCE: My sharp photocopier is AR.5316E,and recently is showing "Ch"
stuck papers on the way.
My Sharp photocopier AR-6020v display E7. and can't make copies what is the problem?
Hello Bheesam,
Turn off the power switch, wait about 10 seconds, and
then turn on the switch again. If this does not clear the
message, write down the code (Main code and sub
code exists.) that appears and then unplug the power
cord and contact your authorized service Rep.
Here is a link for you:
https://www.manualslib.com/manual/885094/Sharp-Ar-6020.html?page=111#manual
1helpful
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Sharp ar 161: cuts off top of page when photocopying
Make sure you have the correct original size and paper size selected and the correct zoom, also the LHS of the window (as you look at the window standing at the front) is the top reference point, line up doc with that. here's the manual. http://olsonbros.com/sharp/specs/pdf/ib-ar160_161.pdf
Error Code E7-11 on a Sharp AR-287 photocopier
This code is related to laser unit functioning problem. Power the machine off and on and if it appears again, do the following;
  1. Open document glass and clean inside mirrors and document glass with a clean dry soft cloth and test.
  2. Check flat cable that connects copy lamp and attach firmly from the main board.
  3. Replace the laser unit if the above fails.
Ask for assistance if you doubt from a qualified technician and you will succeed.
18helpful
3answers
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Sharp Photocopier AR 161
it is the signal h4 if this it is the problem heater unite
2answers
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
