Samsung WF328AA Front Load Washer Logo
k
kimberly david Posted on Sep 25, 2015
Message nf has come up and the washer has stopped. what do i do
Dave Hall
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Dec 17, 2015
Dave Hall
Contributor
Level 1:
New Friend:
Answers
40
Questions
Helped
25684
Points
90
Http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?modelname=WF435ATGJWR/A1&from_osc=&idx=419341&
Washer gives me an "nf" message
I believe you have a Samsung washer. NF means that the washer is not filling with water. Please check if the water supply faucets are opened.
8helpful
3answers
I have an error code that says nf
Hello & Welcome to FixYa
NF error in your washer is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
2helpful
I am getting an error NF during the washer cycle run. The cycle will not complete and has to be restarted. What does this error message mean?
Hello
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
7helpful
I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
1helpful
Washer stops with "nf" displayed on screen
nf is no fill
with samsungs most of the time its a bad resistopr on the cold water vale itself,
check your screens though
9helpful
3answers
VRT with a nf message.
if water flow is OK from the supply, remove the top cover and check the pressure hose that runs from the tub to the pressure sensor. They have a tendency to come loose on these machines. That is what my problem was...Always unplug power before removing covers...
Maytag neptune washer
Since I haven't heard back on this in over a week, I will assume it's been resolved with the clarification questions.
19helpful
2answers
Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
