Radio Communications Logo
Ege Islek Posted on Sep 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Motorola T5022 walkie talkie isn't charging. I can't find answers in Internet.
In dock red lights aren't working. My walkie talkies aren't opening
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Apr 12, 2016
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
796354
Points
4248
Here's a link to the user guide. Not certain if you are unable to open the battery doors on the radio, or if the work "opening" is intended to be something else. Repost if problem persists.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjc47e_9IjMAhWmuIMKHWvLAT8QFggjMAE&url=https%3A%2F%2Fwww.motorolasolutions.com%2Fcontent%2Fdam%2Fmsi%2Fdocs%2Fbusiness%2Fproducts%2Ftwo-way_radios_-_unlicensed%2F_documents%2Fl
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Jan 09, 2008
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Oct 23, 2008
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Jan 07, 2009
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Anonymous
  • Posted on Jul 01, 2009
SOURCE: charging walkie talkies
This is more for "mshtexas" than the OP but I'm sure there may be others out there wondering the same thing. The power cord that comes with this unit has a 9.0v output at 200mA with the center pin being positive
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Jun 26, 2012
SOURCE: Motorola XTR 446 talkie walkie is not receiving
Try programming the radios without an eliminator code and see if they work together then. If so, there is something wrong with the eliminator code portion of the radio. Also, check your batteries, switch batteries between the units and see if the problem moves to the other unit. It takes more energy to transmit than receive, so a bad or very weak battery could exhibit a similar problem. The radio icon will illuminate whenever a radio is transmitting or receiving. When the radio is in standby mode, the icon should not be shown. Your radio with the icon on all the time may be stuck in transmit. Check your PTT button to see if it is slightly stuck or depressed. Here's a link to the user guide http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
Best regards.
I would like KNOW how to use a kem P25703 WALKIE TALKIE
Different Motorola model walkie talkie instructions shown below at the internet link.
You need someone else to have a walkie talkie to communicate with them.
https://www.buytwowayradios.com/products/motorola/manuals/MH230R-manual.pdf
1helpful
2answers
I have a 1998 Motorola Talk about my wife has a work Motorola walkie talkie RMV2080 CAn we communicate with each other if so how ?
No. Your Talkabout radio operates on UHF and your wife's walkie talkie is a VHF radio operating on exclusive business frequencies.
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Motorola batt charger
each has its own technology to charge. they just chare the PS
1helpful
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
Where can I find an authorized repair center for Motorola Walkie Talkies near Pensacola, FL 32505?
I work for the authorized motorola dealer for pensacola, but i work in another branch. Typically we do not service the "walkie talkie" line that motorola makes. For those, you should contact motorola directly. Here is their contact link:
http://www.motorola.com/Consumers/US-EN/Contact-Us/Corporate
When i try To walkie-talkie it wont work
They do not have signal to receive the walkie talkie service. Try texting them and telling them to get in an area where they can get better service. Walkie Talkie coverage is very spotty.
Is kenwood walkie talkie and motorola walkie talkie on the same frequence
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
