SOURCE: washer spins slowly & won't drain
Look at the bottom of the front panel. There on either side is a philips head screw. removing these will release the front panel. the upper part may have spring clips to the top. clearly it is nearly impossible for a sock to get stuck in the pump as the water drains out through all them tiny holes in the drum. look for a broken belt. there should be two of them. the motor is in the left front portion of the washer and is spring loaded to push out from the center.
SOURCE: Baby clothes under the ringer
Loosening top plastic nut and removed top 1/2 of agitator, then loosened nut to lift out bottom 1/2 of agitator.
SOURCE: Water Leak from the Front Door of our Maytag Epic MFW9700S
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
SOURCE: error codes
just fixed mine
i cleaned the filters inside the water lines. disconnect lines where they go into washer use needle nose pliers to pull out screens clean with water and put them back.
this wasn,t the problem with my washer .
mine i took the cover off and found the clear hose from the drum to the water senser had disconnected reattached it with difficulty as i have big hands works fine now
SOURCE: My ge washer shuts off at 19 minutes, but filter is clean
The rug backing may have gone into the pump (the white motor thing) you might take the motor out and flush it out if it is clear and it still won't pump out the pump needs replaced.
