Model 40272900 serial # 001KWRL00862
Showing error code LE
I have cleaned the front panel filter and drained the hose. Unplugged it and tried again, code persists.
Make sure your drain hose is not bent - the code looks like a drain issue. It could be your drain pump. I had to take mine off and it was full of "gunk" and that can keep it from draining, causing that code. I have no affiliation with Home Depot, but they have a great web site showing how to get to the drain pump and how to take it off and clean it or probably just to replace it. Go in to the area to order the part and there should be an option to view a video on how to install it - not too hard, just follow directions. www.homedepot.com/ApplianceRepair
This is an error code for a slow drain or no drain at all problem. It can be due
to a clogged/kinked drain hose, blocked drain filter/coin trap, or a
broken drain pump. The link below provides the detailed troubleshooting
procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs. Error Code E20 on Frigidaire Front Load Washing Machines
Hello,This a common problem for all front loaders. Your washer will not drain
or work 'cause your outlet filter is clogged. Usually this small door
is on the left side front below of your washer. Expect some water to
come out when you open the door, etc. Clean out your filter and
refit.....things should be fine.
LE on your machine means that the hall sensor or motor is faulty. 80% to 90% of the time it is the hall sensor. the hall sensor is located attached to the motor which is accessible if u remove the back panel. if you need any more help please reply.
This is a drain error as you have figured out Good Job!
Now this can be caused from a broken impeller in the pump and or a plugged tub to pump hose.
Have you washer any rugs which may have came apart in the wash?
If so the hose from the tub to the pump may be restricted causing the code.
The hose will need to be cleaned.
This is a job best left to a pro.
check your drain hose for kink,,when you cleaned filter did you check for coins in the impeller..also check drain pipe for slow drain problem,,check the pump connection and make sure its not slipping off..onthejob
