Samsung S860 Digital Camera Logo
Posted on Jul 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blurry Display Screen and 2 beeps with shutting Off
Just out the blue my camera stop functioning properly. When I turn on the camer my display area shows a blurry live feed. When I take the picture it is blurry as well. When I turn off the camera it has 2 beeping sounds.
Anonymous
Level 2:
Sergeant:
  • Expert 199 Answers
  • Posted on Jul 13, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
199
Questions
Helped
81910
Points
661
Check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Kitchenaid KDPM604KPS dishwasher stops minutes into cycle
I couldn’t find any error code 2H but I did find an error code H2O. This code means insufficient water pressure. If the display reads 2H, it usually means the start delay function is turned on. The dishwasher will turn on in 2 hours if door is closed. This dishwasher is advanced. To understand all operations you should read the user guide or manual.
1helpful
Sony DSC-S700 when turned on sometimes the screen is blurry and pink toned with blurry grey lines running accross the screen. Photos turn out the same. Happens intermittently. Have changed batteries,...
Hi there some how your camera LCD pressed by out side & the screen is damages. That's why you get the lines. Specially its come some particular area in the LCD screen. Just the way of resolve is resolve the LCD screen. Thanks & waiting for your feedback.
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Pictures are not sharp
On most camers that means you are going to get a blurry photo because of camera shake. Using the flash should take care of it. You may have the flash set to "flash off" mode accidently, and in insufficient light the shutter speed is too slow to stop blur.
Mar 17, 2009 • Cameras
Camera turns on then shuts down
hi...ensure  that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears.  Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
thank u rate me!!!!
2answers
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Grey and white screen--lens won't open--beeps and shuts off
i have fe170 olmpus camera but the lcd display is dameaged ies the corrner of the display is colour is changed how can service this problem
1helpful
2answers
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
13helpful
6answers
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
