The tv turns off by it self
Your problem resides in two places, the A/V board and the main system control board assembly, as for the unit switching off and on this is an indication of a bad lamp, the unit has a lamp usuage timer that records the amount of time on the lamp, it needs replacing if it has been more or near two years as the lamp is only good for 6500 hrs of use, thats ruffly three years, The componet input not working is due to a bad switching IC on the A/V board, Replacing the Audio/Video board will solve the input problem. The A/v Board plugs into the main board assembly.
Apart from these the other possibilities are:--
1)loose solder connections can cause short tracking. Get the board re-soldered to fix this issue.
2)faulty or bulged out capacitor causing short tracking.Get the faulty capacitor replaced to solve the problem.
3)the unit gets over heated internally and shuts itself.Keep distance between tv and wall and keep a desk fan behind the tv to keep it cool while you are using the tv and check. overheating can be because of internal fan problem.
Thank you!
