Checked the filter is clean comes up OE on panel how do I change the pump
If there is a back panel on the machine you can access it from there, if it has a enclosed back then you will have to lean the machine backwards against the wall to get underneath to access it. The pump has two wires attached to it make sure the power is off & lead removed from wall before you unplug them otherwise you get zapped. The drain pump is held into the pump casing/housing by three Phillips head screws. Undo the screws remove old pump and replace with new pump, make sure rubber seal is on the new pump before installing. You will need a torch & a Phillips head screw driver.
Hi
OE in your dishwasher is a
drain error and dishwasher not draining issue usually occurs due to kinked
drain pipe, clogged drain filter or drain pump. First make sure that the drain
is not clogged and remove clogs if present. If no visible lint is present then
remove the lower front access panel to check the drain filter and drain pump
for any clogs, you'll need to clean the drain filter and drain pump completely.
Also, check for any food pieces stuck near the pump impeller & clean the
chopper assembly. If the issue
returns after cleaning then the drain pump assembly should be replaced. Hope
this helps...please post back for further assistance.
Daniel
