Question about Microsoft Excel Computers & Internet
Completed, Avgdays, USER, Waitshop,inshop,Waitpart and Waitpickup. Using these fields, how do I calculate turnaround time for wait pickup time?
Comp Avgdays user Waitshop in Shop Wait part Wait pickup 67 12.73 12.73 0.76 3.07 11.17 0.16 how do I get the calculation for the turn around time for waiting pickup which is 0.16
6ya staff
SOURCE:
Anonymous
  • 28 Answers
SOURCE: Calculated field in Excel pivot
Count will only work with numbers. So select another box where you want your number and use this formula: =count(x:x) This should give the count number then you will need to find the difference. In another box, use =sum(x-x). This should give you your difference.
If this helps you, please rate me. Thanks, Patty
Posted on Dec 30, 2007
Anonymous
  • 7 Answers
SOURCE: formula for Calculating the turn around time in excel
dpprash,
I guess you mean the number of weekdays (or working days) excluding Saturdays and Sundays. So start a spreadshhet and put the start date (01/01/2009) in A2 and the end date (31/12/2009?) in B2.
Then paste the formula below into C2:
=B2-A2-2*INT((B2-A2+WEEKDAY(A2,3))/7)-MAX(0,WEEKDAY(B2,3)-4
better-swiss
Posted on Dec 19, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: slow for open file at freehand mx 11
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Posted on May 21, 2009
freddyg2003
SOURCE: cannot select calculate fields
maggie57, I also have the same problem, but I have discovered a workaround. Use the spacebar to select/deselect individual items in the field chooser.
Posted on Jul 14, 2010
Nigel Sage
  • 28 Answers
SOURCE: Hello Please can you help. We
This is usually caused by the user not having full rights to the Data directory. right click on the data director select security and you can a click on users network logon and tick on full control
Posted on Nov 15, 2010
What Is The TAT Or Turnaround Time In Loan Pre-Qualification?
The lender makes an effort to provide a 24 to 72-hour loan pre-qualification. The process from the completed application submission to disbursement of funds takes roughly 1-3 months, with respect to the complexity from the project and also the loan.
Oct 21, 2015 | The Computers & Internet
How to change password to small
Open your preferred internet browser and enter "192.168.1.1" in your web browser's address field.
When login dialog box will appear,leave the user name field empty. Input "admin" in the password field. Click "OK" to log into the router. The blank user name and "admin" password are the default configuration settings for your router.
Click "Security". Type the new password you want to assign to the user account. Enter it again in the "Re-enter to Confirm" field. Click "Apply".
Close your internet browser after you have completed the password change to protect your router from unauthorized access.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 19, 2012 | Linksys Wireless-G WRT54G Router
Deg won't to comp,etc.
As a first time user, the only way to start is to read (at least skim) through the user's guide. If you have no time for that and you need assistance with a particular question take the time to formulate it in an understandable manner. It would have been my pleasure to help you, if only I understood what you wanted. Please try again.
May 26, 2012 | Casio FX-260 Calculator
How to set date and time on sharp el-1801pIII
User guide is here ...
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/EL-1801PIII-_E
Instructions are halfway down column 1.
Basically, you use the reset button on the back, then enter the relevant fields, delimiting as with a period <.>
I think their illustration explains it better than I can in words!
Feb 28, 2010 | Sharp EL-1801P Calculator
TI84 does not work!
Perform a manual Garbage Collect.
  1. Press [2nd][0] to access (CATALOG)
  2. Press [TAN] to jump to first command that starts with G.
  3. Find GarbageCollect
  4. Press [ENTER][ENTER][2:Yes].Garbage collection may take up to 5 minutes
  5. After garbage collection is finished retry transfering data to calculator.
Uninstall and reinstall the TI-Connect software:
  1. Go to Start >> Settings >> Control Panel or Start >> Control Panel and select "Add or Remove Programs".
  2. Locate the TI-Connect software in the list and then choose "Remove".
  3. Once the software uninstall process has completed, please shut down and power off the computer.
  4. Wait approximately 20-30 seconds and then reboot into Windows.
  5. Download and install the latest version of the TI Connect software from the TI Connect Software home page.
  6. Once the TI Connect software install process has completed, restart the computer before using TI-Connect.
  7. Attempt to transfer data to the calculator.
If these steps do not solve the problem contact TI
Jan 30, 2010 | Texas Instruments TI-84 Plus Calculator
Simulate the Shortest Job First CPU scheduling algorithm
Nice try! Find an upper-class student to give you one-on-one tutoring for your homework.
Jan 14, 2009 | Computers & Internet
Locked out of Comp
Hi
If u r using windows Xp then on the login screen press ctrl-alt-del
continously for two to three times and then fast user switching login window appears.
just enter username as "administrator" and leave the password field blank.
U will be logged in as a admin, now do whatever u want with ur old account.
Jun 27, 2008 | Toshiba Satellite A205-S4617 Notebook
PROBLEM W/ CASIO fx-260 SOLAR
Sorry, but I think you misunderstood what the manual says. See the not on the screen capture.
True the sentence is not very clear, but what it means is the following:
All modes (except COMP) will have an indicator (with the appropriate labeling) displayed. When in COMP mode the COMP indicator is not displayed.
The truth of the matter is that computation- wise you have two MODES only : the general COMPutational mode and the Standard Deviation (SD Statistics) MODE. These two are incompatible because the key layout is different.
But to compute trig functions
  1. calculator must not be in SD mode, hence it is in COMP mode
  2. An angle unit must be shown on display.
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Jun 04, 2008 | Casio FX-260 Calculator
Computers & Internet Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
