hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this at reliable-store
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
HI, Check the following video to know how to align the treadmill belt which is going to one side. All trad mills have the same procedure to align the belt.
Clean your coffee mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
Unplug your coffee mill.
DO NOT PLACE THIS COFFEE MILL IN WATER. DO NOT IMMERSE THE BLADES OR MOTOR BASE IN WATER.
Remove the coffee mill cover and brush. Wash both in warm sudsy water. Rinse and dry each thoroughly. The cover and brush are NOT dishwasher safe.
Use the Built-In Cleaning Brush to sweep out excess grounds. Use a clean cloth or paper towel to remove any remaining grounds.
Be sure to clean your coffee mill completely after each use.
Do not try to oil or sharpen the blades. The blades are permanently lubricated and never need sharpening.
hi, i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power. ok
This portion rarely needs replacing. It is designed to pull easily away from the brush side in case of blockage and then may need to "unscrew" use only the identical component form an AERUS Electrolux dealer. This should be accomplished without dismantling the head. If there is evidence of glue or contact cement type adhesive on the bag side, you may need to tear apart and unravel with pliers
Take a box cutter blade or something razor thin and locate the 2 screw covers on the handle. Pry the two covers off and remove the 2 hex screws. Pull handle apart. Done. Might want to check your elbow down on the power nozzle before you rip apart that handle though. 4 out of 5 times, the problem is in the elbow.
