So far I have only done three loads of laundry. I haven't used any fabric softener. After the load is done, the fabric softener dispenser is full of water. Is it supposed to be? I doubt it. I'd like to take the dispenser out and clean it. The Instruction Booklet says to pull firmly and it will come out, but it's going to take a very hard pull, and I'm afraid it will break. Thanks.
SOURCE: Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
SOURCE: Fabric Softener dispenser
thats quite normal, espessially if you do not use the fabric softener, the compartment empties through an overflow siphon action, so if there eis nothing in the compartment the area is flooded but cannot cause siphon action, not an issue at all
SOURCE: some water backs up in the softener dispenser??
Service was here today and tilted the machine backward about 2-4 degrees. This solved the problem. Now fabric dispenser fully empties. Since the machine is 2.5 year old it is possible that over time it settled. I think though it is more likely the cold water dual inlet solenoid that is a bit constricted. If this fix does not last I will change it.
SOURCE: fabric softener dispenser not working
If the model number you have this listed under is correct, you should have the softener dispenser on the center post of the agitator. If this is the case, you need to remove it by popping it off the center post and take it apart. Soak it in some hot water to dissolve the softener residue and reassemble. Most dispenser related problems are attributed to softener that hardens and clogs up the dispenser. Liquid softener is essentially a wax and will do this over time. You will need to clean it from time to time.
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
